Hot Rods New engine build overheating help
Discussion in 'The Hokey Ass Message Board' started by boy_named_sue, Jul 21, 2025.
  1. boy_named_sue
    boy_named_sue
    from Dayton, OH
    Freshly built 350 in my 48, got it broke in, started and timed and running good, but it’s overheating…weirdly. It take a good long while to get up to temp, and when idling it will sit there and stay pretty stable. AC on or off, doesn’t seem to make a difference. While driving, it will verrry slowly creep up and up and up, and never really go back down. Not with speed or anything. On the highway it will come down a little and hold temp, but around town it’ll start pushing past 240 and that’s when I cut it off. But even there, I’ve arrived home at 240 and let it sit and idle for a minute to see what it will do, and it doesn’t move when I stop. But every so slowly even will come down a little (220 after about 20mins).
    engine is a 1995 tbi block, I put a small RV cam in it, lowkey port job on the stock heads (just knocked of the casting marks mostly) and an Edelbrock o take & carb. Now I know you’re gonna say “there’s a million factors” but here’s where I’m at: I pulled an old tired 305 out that never overheated once in 4 years, and changed nothing but the engine. Same aluminum rad, same electric fan, same thermostat, water pump, intake, carb, headers… literally I just undressed the 305 and put its clothes on the 350.
    I have checked and confirmed coolant moving through the upper hose at temp (therm is also brand new, just in case). Burped all the air out of the lines, heater hoses are flowing fluid. Electric fan is working fine. Radiators not blocked.
    Any suggestions? With Frog Follies coming ip I’m getting close to just yanking it and putting the 305 back in. But would love ideas for what else I could check first. It really feels like there’s some kind of fluid restriction to me, but I can’t think of a way to figure out where. Any of you ever had something like this??
  2. boy_named_sue
    boy_named_sue
    from Dayton, OH
    And just in case it helps to be extra clear, same distributor, timing is correct, and no it’s not a reverse flow pump.
    again the weird part here is that it’s FINE at idle, and it seems to heat up when under load. That’s what’s got me boggled. Unlike all the other things I’ve overheated in my lifetime.
    thanks again for any help or ideas
  3. deathrowdave
    deathrowdave
    from NKy
    Vacuum Advance working correctly is a must for cool street driving
    jim snow and osage orange like this.
  4. Bandit Billy
    Bandit Billy
    Did it get hot during the break in? Is it getting hot enough to puke? Same or different temp gauge? Are you checking temp gauge against an IR thermometer? Did you do the rebuild?
  5. jimmy six
    jimmy six
    Did you degree the cam? A retarded one will cause added heat and run a little sluggish from idle up to 2000. Also some rebuilder knock the freeze plugs inside instead of removing them this also doesn’t help. Good luck.
    bschwoeble likes this.
  6. lostone
    lostone
    from kansas
    What are you using for a fan ?
  7. RodStRace
    RodStRace
    Reading thru this, it shouldn't. Same parts, fresh engine. I ***ume it wasn't mud in there before and you didn't pull a "DOH!"
    One thing stuck out to me. New thermostat and you thinking poor circulation, which sounds right. But before you said old tstat. Was the change an attempt to repair? Same results?
    Especially these days, new doesn't equal good, it just means untested.
    joel, osage orange and Just Gary like this.
  8. primed34
    primed34
    You checked with a temp gun? I thinking thermostat.
    osage orange likes this.
  9. TA DAD
    TA DAD
    from NC
    Standard bore or has it been oversized ?
  10. Radiator IS to small. OR partially plugged. If my hillbilly math is correct, the cubic inch has increased by about 13%. Radiator may have been ok, but on the ragged edge, with the 305.
    I overheated my Buick badly. I had gone from a 248 ci to a 263 ci bored to about 290. The original size radiator cooled the 248 + AC ok. It could not handle the 290 + AC. A radiator for a 320 cools so well the engine STRUGGLES to hit 190 on a 100 day.
    Get a larger capacity radiator
    Ben
  11. 19Eddy30
    19Eddy30
    from VA
    I say , If you have correct water pump
    For for direction you are using
    I am ***uming standard rotation,
    Timing & carb tuning ,
    If you know your TDC is correct 0
    Your timing , engine will be around
    14 deg BTDC plus @ Idle . Rv
    Maybe as much as 18 ish
  12. Magneto Bryan
    Magneto Bryan
    I would check that the lower radiator hose is not collapsing. If you do not have a spring inside of it, or if it is old, and does not have a spring in it. That could be the issue you are having.
    BJR and Moriarity like this.
  13. alchemy
    alchemy
    Did you check your new thermostat in a pot of water on the stove?
    alanp561 and Just Gary like this.
  14. TA DAD
    TA DAD
    from NC
    Fresh motor (more heat), more cubes (more energy) temp goes up under load which is pretty standard sounds like it just needs more radiator .
    osage orange and firstinsteele like this.
  15. pirate
    pirate
    from Alabama
    Not mentioned and a long shot but could there be air trapped in the water jacket. Is the radiator fill cap the highest point in the cooling system? You could try jacking up front of car, starting engine with radiator cap off and see if it purges any air.
  16. jaracer
    jaracer
    The symptoms point to not enough cooling capacity. Have you tried spraying a hose on the radiator when it is hot? That will at least tell you if the cooling system is working.
    It looks to me like this engine wants a bigger radiator. When you ask it to make power, the radiator doesn't have enough capsctiy to keep it cool.
    firstinsteele and osage orange like this.
  17. FRANK GRELLE
    FRANK GRELLE
    Is the thermostat in backwards?? sounds obvious but we all have the ability to screw up , It may be from the 2 beers wile working on the car on a Sunday nite or anticipation of firing up a new build and rushing to get done,
    porkshop likes this.
  18. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I believe @Bandit Billy called it.
    In a case like this I would use ( I can hear the sighs ) I look to, , , ,
    Marvel Mystery Oil.
    Often debated but it works, if the engine may be a little tight, causing heat from friction build.
    Start with a quart split Pint in the gas and Pint in the engine.
    Take the night off get on the hi-way ( aka 4 lane )
    Start with the speed you had troule before and subtract 10 MPH,
    In time, you'll know, give it more throttle, eye on temp.
    Keep playing with slow and faster for a while.
    Repeat if neccesary it may take more time and MMO
  19. Joe H
    Joe H
    Was the engine tight before you started it? Thick old school rings, or thin modern rings? Rough cylinder hone, or extra fine? Most new motors run hot for awhile, how many miles does it have on it?
    Tow Truck Tom likes this.
  20. leon bee
    leon bee
    I didn't see if you pulled the thermostat out and tried without it.
  21. tubman
    tubman
    I had the engine in my Corvette completely rebuilt about 15 years ago. It must have been tight, because it ran hot from the git-go. I could live with it most of the time, except you couldn't let it sit and idle for more that 5 minutes or it would boil over. After about 2000 miles of this ****, I decided it was time to pull it and tear it down. All of a sudden, it quit the boiling and has been a model of decorum ever since. (Except for having to replace the "High-Pressure/High-Volume" oil pump for a stock replacement unit to keep the oil pressure gauge from being constantly "pegged". I think the two were related.)
    Tow Truck Tom and osage orange like this.
  22. lostone
    lostone
    from kansas
    Like I stated in other posts before.
    I built all my engines tight, they'd get hot and this is how I broke all of them in. Cruise the local main drag until the motor got up around 220 or so, pull into car wash and with motor running hose down radiator until 140 or so then off and do it all again.
    Heat it up, cool it down. A night of cruising doing this. Once I was done cruising and after many heat cycles, I'd cool it down one last rime and head straight home. The next day was a new day and never had an engine run over 180° no matter what I put it thru.
    lostn51, osage orange and 427 sleeper like this.
  23. boy_named_sue
    boy_named_sue
    from Dayton, OH
    vacuum advance interestingly makes the car stumble and respond poorly to throttle, so I have it capped off currently. While it’s a puzzle to me, it Drives great that way. The 305 really liked the vacuum advance to the port side of the carb.
  24. boy_named_sue
    boy_named_sue
    from Dayton, OH
    yes I did the rebuild myself. First one ever, but I took my time and went “by the book” and so far I don’t seem to have any kind of failures. Just this creeping temp. Yes it’s the same exact gauge and sensor and wires and everything I was previously using with no issues (and also fairly new, less than 5yrs old). Yes I compared temp reading with IR therm shot into the water at the radiator, as well as at various points along both hoses. Everything agrees.
    during initial break-in, temp was just fine. But it was only about 20-30mins without moving. I am still technically in break-in phase as I’ve only gone for about half a dozen short drives with it since then due to overheating.
  25. boy_named_sue
    boy_named_sue
    from Dayton, OH
    it’s a 4yo aluminum radiator rated for a v8, I’d have a hard time believing it can’t handle a very plain 350.
    and to answer others: yes I’ve checked, re-checked, and triple checked the thermostat. Even tested it in the wife’s pot on the stove with a thermometer in the water. I am 100% positive thermostat is working properly (although it’d be awful convenient if that was the problem).
  26. boy_named_sue
    boy_named_sue
    from Dayton, OH
    same 3000cfm electric fan I had in there previously. It’s less than 3yrs old and feels just as strong as the day I installed it. Also can’t believe it’s the fan because at speed is when it heats up, not cools down. It actually behaves pretty nicely at idle
  27. boy_named_sue
    boy_named_sue
    from Dayton, OH
    lol I am very not beyond something stupid. I do all of my work after 10:00p so anything is possible. But no, I am sure the thermostat is ok.
  28. boy_named_sue
    boy_named_sue
    from Dayton, OH
    I’ve richened up the carb and messed with the timing til I’m blue in the face. I am 99% sure it’s not timing. Swapped out for a known good one just to see if maybe the mechanical advance was acting weird and it drove exactly the same. So almost definitely not timing
  29. 19Eddy30
    19Eddy30
    from VA
    What is static timing set @ ?
    Gear chain set , only one way or
    3 way
    Also to be clear 95 & older ?
    split year ,
    & Not LT1 .
    Intake is it 12 bolts or 8 bolt intake ?
    The reason I ask about intake 12 bolt uses pretty much 60s to 1995
    Thermostat,
    The 8 bolt intake takes a Double spring thermostat .
    Heads , Valve cover center 4 bolts
    Are you using Heater Hose ?
    Are you using by p*** port on block ?
    Water pump , do you know for sure water coming from intake to Radiator.
    The reason I ask if you have ever read any of my post , I have done some unusual things to stock parts , for my own application and I'm sure I'm not the only one who has thought of these.
    1 , I have taken a
    "" Standard water pumps "" a part and reverse them by changing the
    "" Propeller""
    Also asking where is you temp gauge
    Sender Located ?
    The reason I ask this ,
    About a year ago I stumbled up by accident playing with Temp gauge location ,
    One side engine hotter then other side
    By 20-35 deg's I @ one time 8 temp gauges just on block / heads @ same time , all where calibrated & noted ,
    I was Not going to pull heads , Have my reasons Why Not to ,
    I read on Line this was a common issue,
    With 1st Gen Sbc /Bbc Not known to many Because Most only have
    One gauge , I can also tell you 6 of 8 gauges
    Read different except the 2 that where On intake @ Thermostat , 1 on each side
    2-3 deg's different.
    I tried / experiment many different ways of pluming coolant to balancing
    Both sides of engine ,
    Most this would Not matter to ,
    SB2 engine solved this issue.
    My solution was to force water threw block , exit @ rear of intake one side
    With #8 line the other side with #12 line
    & @ front of intake a # 3 line
    rod1 likes this.
  30. boy_named_sue
    boy_named_sue
    from Dayton, OH
    Thanks so much for all the replies. I’ll post on here if I get it licked
