new exaust what dia.?
Discussion in 'The Hokey Ass Message Board' started by crescentwrencher, Mar 17, 2008.
  1. crescentwrencher
    crescentwrencher
    ive got a ford 390fe and im gonna redo the exaust system on it with simple old true dual and glass packs.
    my question is what diameter should i use? my brother says i should use three inch but i was thinkin 2.5"
  2. HotRod31
    HotRod31
    IMO I think 2.5 would be your best bet.
    Later, Mark
  3. Rich Rogers
    Rich Rogers
    I'd say 2.5 would let the motor breathe well and perform better than 3in
  4. crescentwrencher
    crescentwrencher
    why dont smithys come in 2.5, did they think every body had a small block er somthin?
  5. crescentwrencher
    crescentwrencher
    how about the length? i was thinking 24" with 18" case.
  6. Danimal
    Danimal
    1. A-D Truckers
    All depends on what you are putting it in. Open cab, truck, car, sedan...2"-2.5" is fine. If you've got a closed cabin, you probably want more tuning volume so you don't get that DROOOOOOOAAAAAANNNNNN in your head going down the road. Then again, if you've got some teeth that need to be vibrated out, it might be fine!
  7. crescentwrencher
    crescentwrencher
    its a closed cab pickup, i want it lound outside the truck, so i was thinkin of welding them in uder the bed.
  8. crescentwrencher
    crescentwrencher
    im thinking of using brockman mellowtone steel packs, anybody use these before?
