Technical new firewall suppliers?
Discussion in 'Traditional Hot Rods' started by Steve Reddy, Nov 9, 2025.
  1. Steve Reddy
    Steve Reddy
    Hi all, looking at buying a firewall and floor kit for an A sedan….*****in Products or Brookville Roadsters ***emblies? I can get four inch recess kits from either of them. Leaning towards the Brookville because it looks more original. Any thoughts?? Fitting a Ford 302 in a stock dimension frame and wanting to retain stock hood. Thank you!
  2. RodStRace
    RodStRace
    Steve Reddy likes this.
  3. Steve Reddy
    Steve Reddy
    Thanks for that. One reason I’m looking at Brookville is they are closer and the upper part of the firewall still looks stock. I have already bought the cowl top from them as well
  4. uncle buck
    uncle buck
    You don’t mention what the firewall is for?
    lothiandon1940 likes this.
  5. krylon32
    krylon32
    from Nebraska
    I'm ***uming it's for a model A? Give Jeff a call at Absolute Sheetmetal. Good Mom & Pop company making a excellent product.
  6. Steve Reddy
    Steve Reddy
    Yes, Model A! Sorry
  7. Just Gary
    Just Gary
    Or 1930-31?
  8. Steve Reddy
    Steve Reddy
    1930
    Just Gary likes this.
  9. pprather
    pprather
  10. 3blapcam
    3blapcam
    Just flip the stock one and be done. If yours is garbage, find one that isn't. There are plenty of them out there. *****in firewalls look dumb.
    3blap.
    gimpyshotrods, alanp561 and Just Gary like this.
  11. continentaljohn
    continentaljohn
    As said by @pprather and @3blapcam suggests just flip the firewall and you’ll have plenty of room to fit the sbf.
    Now that you want to go with the 302 ford I recommend you shorten it up a bit with a Motorsport SVO waterpump 90degree oil filter adapter,Motorsport headers as they dump in the back by the firewall rather then the middle. Your motor mounts are in the middle so the headers will be out of the way and with a few simple plates you can fab up engine mounts and just use the brisket style mounts. Being you are using a 1960s motor build and so . The steering box you can use Saginaw style box like. 525 out of an early jeep 1972 and newer and bury it under the motor mount and oil filter. The alternator and be buried on the p***enger side using an early ford bronco smog / ac bracket.
    You can dress it a bit more traditional with Bluethunder motor sports parts . They make Shelby engine speed goodies such as Weber setups or 3x2 intakes . Remember Carol Shelby’s cobra with a 260 289 ran pretty darn good
  12. uncle buck
    uncle buck
    I believe Ford discontinued the pulley for this pump. I found CVF Racing now offers the pump and pulleys and I would take John's advice and use it
    continentaljohn, Outback and alanp561 like this.
  13. continentaljohn
    continentaljohn
    Thank you @uncle buck didn’t know about the discontinuation . The past supplier was a local CNC manufacturer that making numerous parts for Ford under there license. I did have to machine the waterpump pulley but sold me a raw blank unfortunately this was many years ago.
