New Flathead starter..
Discussion in 'The Hokey Ass Message Board' started by stromberg, May 19, 2011.
  1. stromberg
    stromberg
    Has anybody used one of the new flathead starters like Powermaster or the speedway stump puller starter?
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Nope,
    There are just too many used stock ones out there that will last longer than the engine. Even when running 12 volts. Macs auto sells those new style bendix that wont break also. Pain to install but they work.
  3. stromberg
    stromberg
    I will look him up. Thanks.
  4. George/Maine
    George/Maine
    I'm running a c4 flatomatic kit and the mini starter works great ,because drives from other side of flexplate.
  5. stromberg
    stromberg
    Why are they a pain to install? is it harder than the stock starter? Its just 3 bolts.
  6. Retrorod
    Retrorod
    We have one of those from Speedway on Flower's 8BA roadster. It works very well. It probably will outlast the car. It just bolted on, no drama.
  7. stromberg
    stromberg
    The stump puller? I was going to order it, but they couldn't tell me if it had a one wire power like the stock, or if it had two like the powermasters do. What does yours have?
  8. DICK SPADARO
    DICK SPADARO
    Why would you bother a stock stater works just fine, your flatty should fire with about 1 revolution of the engine. This is another example of newer isn't necessarily better.
  9. stromberg
    stromberg
    The stock starter took a dump, time to replace it.
  10. Ford Guy
    Ford Guy
    I installed the Powermaster last month when I pulled the engine to change the trans. Seems to work okay, but it's only been started a dozen times or so. The original starter (6V) was working fine, like everyone says and probably would outlast the truck. I just got a wild hair and ordered the Powermaster a couple of years ago and never installed it until now.
  11. ibcalaveras
    ibcalaveras
    I got a power master it works well. But it was to close to my header. I didn't want to rework the header, so I rebuilt the old one. Apparently Ford tractors use the same starter, so parts are not hard to come by. The rebuilt one works just fine.. I'll save the power master for for something else, or sell it...
  12. johnny bondo
    johnny bondo
    from illinois
    if you are a real man, you will hand crank it..........;P
  13. Retrorod
    Retrorod
    One solenoid wire...one large "power" cable.
  14. stromberg
    stromberg
  15. 40FordGuy
    40FordGuy
    I went PowerMaster on mine...works great ! And, it even sounds like to old timey ones. Another thing, if your ring gear ia a bit "chewed", the P M gear engages the ring gear from the front,...the originals engaged from the back side of the flywheel.
    4TTRUK
