1952-59 Ford New from San Diego
Discussion in 'Off Topic Hot Rods & Customs' started by mort58, Sep 27, 2011.
  1. mort58
    mort58
    Hello all, I recently purchased a 54 Victoria and will be starting the restore soon. The car is complete and original. Thinking of going with a modern drive train vs rebuilding the old.
  2. the-stig
    the-stig
    Welcome from So Cal. I just finished putting a 302/5 speed in my 56.
  3. baker53
    baker53
    Hi Mort, Welcome aboard. I also have a Victoria. It is a '53 with a '54 dash. Bill, Spring, TX
  4. flyboy89
    flyboy89
    from So. Cal.
    Welcome, Mort, from another SoCal'er. I'm using a 351 with AOD and a '70 Maverick rear axle. The car is a '54 Club Coupe.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Mort,when you get ready to start collecting parts put the word "sticky" in search here and a bunch of goodies will come up with part numbers you will need for the swap.
  6. Baggs
    Baggs
    Welcome!! i just finished installing a 302/aod combo in my 54 with alot of help from the board and jeffb2!! great info on here, all you have to do is ask!!
  7. fxcomet
    fxcomet
    Welcome! FE and auto in my 56.
  8. mort58
    mort58
    I can tell already that this forum is going to be great. Thanks!
  9. skoh73
    skoh73
    Welcome from WI!
  10. 54HotRod
    54HotRod
    Welcome to the group. I'm also in San Diego, but I'm downtown. I've got a 351W with a C6 in mine and that seems to work out fine when its running.
  11. guthriesmith
    guthriesmith
    Welcome to the group from Oklahoma!
  12. riskybiz
    riskybiz
    Mort, Welcome to the group from Nor-Cal. My 54 Victoria 312/fmx, 54 coupe Chey 350/700r:D 55 Victoria 302/c4
  13. kustomcar53
    kustomcar53
    Hey there, have fun with the Vicky! I have a '54 tudor with a 302 hooked up to the original 3 speed. Easy swap and runs great!
  14. mort58
    mort58
    So, how do you change your icon on this forum?
  15. skoh73
    skoh73
    Mort go to the control panel on the left hand side of the screen on the main board and click on "edit avatar". Then upload an image from your library or online. If you need any further help shoot me a pm.
  16. Retro Jim
    Retro Jim
    A nice 302/5.0 roller cam engine would be a great choice with either a T5 trans or an AOD trans . Depending on the gear ratio , if you don't build big HP & Torque engine , you can use the rear you have now . Now if you had a 6 cyl with a standard trans in your car , you will have to either change the gears or the easiest thing to do will be sap out your rear for either a 8" rear from an early to mid 70's Mustang , Comet , Maverick , Cougar . The gear ratios ate usually 2.79 , 3.00 but some have 3.25 ratios . You can also get a rear from a 1957 car and up 9" rear that will work as well . The gear ratios for them are endless that you can but . The width will be fine from the cars up to the early to mid 70's . If you are really lucky you might find a 9" rear from a Cougar or Mustang !
    We can give you all the information and where to get some parts at the Very BEST prices around ! Disc brake conversion's are also east to get .
    Good Luck with your project !
    Jim
  17. vein
    vein
    welcome! Seems like everyone here has a 302 except me with an inline 6.
