New, from St. Lou
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Greasy Chevy, Nov 27, 2008.
  1. bobblehead
    bobblehead
    If I recall, silveradoman has a s10 rear end under his 52 chevy...but i would check with him.
  2. Greasy Chevy
    Greasy Chevy
    did s10s have a 8.5? that's what id like. i'm under the impression 70-81 camaros will work. ive located a couple on craigslist so well see what happens with those.
  3. bobblehead
    bobblehead
    i want to say that they are 8.5s but i am unsure.
  4. 53dodgekustom
    53dodgekustom
    4X4 S-10 is the one you want, the 2wd S-10 rears are to skinny. Yes, the 2nd gen F-bodies are also a good choice. There is like a million threads on converting your car to an open drive line. Do a search there is a ton of good info on your car on here. Are you planning on keeping the six? They are fun!
  5. Greasy Chevy
    Greasy Chevy
    i found a rear end on craigslist out of a camaro i don't know if its 8.5 or 8.2 but its a ten bolt 4.10 gears and posi i'm gunna go look at it tomarrow.
    no the guy i got it from had the engine but he said it was locked up so i left it there. gunna put a small block in it. id like a 327 but prolly just do a 350 for now since theyre easy to find and cheap.
  6. Dads-53
    Dads-53
    Welcome from the other side of MO. Have a 53, built in 84 and still running . painted three times now, so if I can be of any help PM me.
    Don
  7. When you make the switch i might be interested the torque tube rearend....
    If it came with a powerglide its got better hiway gearing, 3.55, then the earlier years, or those with a standard transmission. Us guys that keeep the enclosed drive shaft likem.
    If you havent found it already, chevs of the 40s can be a good place for parts. They have an online store, but its worth getting the catalog.
    Its amazing how much stuff is at your local parts hut.
    1st thing you should do is get on ebay and get a good shop manual....
    Heres an online version for ya......
    http://chevy.oldcarmanualproject.com/shop/1949_53/index.htm
  8. Greasy Chevy
    Greasy Chevy
    it was a 3 speed car. but when its out id be willing to trade it for help and knowledge.
