new fuel pump from ecklers is leaking?
Discussion in 'The Hokey Ass Message Board' started by bungle, Aug 14, 2011.
  1. bungle
    bungle
    from el paso tx
    have a question about my new fuel pump. i have a 54 chevy bel air, i just replaced gas tank and fuel pump due to rust issues. i got a new tank from ecklers, new sending unit from ecklers as well(holes in sending unit were off a little and didn't match up, but no big deal, easy fix). anyway, the car runs great, no issues, doesn't stall, fuel is being pumped to carb, but when i look down at the new pump, i see fuel sweating out of the black gasket at the top?
    is this normal? i've checked my lines and they seem to be dry, plus the fuel would have to go up to get on that part of the pump. the two screws on the top can't be tightened any more. is this normal? will it seal better as it wears in, or do i have a defective part?
    thanks
  2. Hitchhiker
    Hitchhiker
    Leaking fuel is bad.....I think it's defective....but am curious as I am about to install one too.
  3. unkledaddy
    unkledaddy
    It shouldn't be leaking anywhere.
    Suggest you call Eckler's and discuss it (waranty) with them BEFORE you take it apart.
  4. pug man
    pug man
    from louisiana
    Maybe it's just the gasket not seating properly. If you don't have that much money in it, take it apart and put some gasket goop around the edges and see what happens.... my 2 cents.....
  5. bungle
    bungle
    from el paso tx
    yhea, i was thinking about that. i took my old pump apart just to see what was under there. i don't think ecklers will take it back, but i guess i could ask before i take it apart.
