1952-59 Ford New gauge panel in 56 wagon
Discussion in 'Off Topic Hot Rods & Customs' started by Slicks, Oct 23, 2016.
  1. Slicks
    Slicks
    from denison tx
    Here's a photo of my new gauge panel for my 56 wagon.
    Rui, DSmoke and DIYGUY like this.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. okiedokie
    okiedokie
    from Ok
    Man do I like that.
  4. chopd top
    chopd top
    from Florida
    Sharp lookin'!!
  5. 56FORD390
    56FORD390
    I LOVE IT.
    What did you use for gauges?
    What are the diameters of each?
    Did you have to modify the dash panel at all?
    How did you get each gauge mounted?
    Is that the original bezel around the gauge?
    You have convinced me to do the same to my ride.
    Only difference is that my panel will be gray.
    I am gonna do it, I am!
    Thank you, Slicks
    Also, what is the tiny red dot in the upper center?
  6. bobss396
    bobss396
    Dot, hi-beam indicator? Looks quite sharp.
  7. 56FORD390
    56FORD390
    aaahhhh, yes, high beam. I should have known. Thanks
  8. Texas57
    Texas57
    Purdy!!! I looked closely thinking they were Speedhut gauges...then saw the Cl***ic Instruments. What kind of Speedometer is it....GPS by any chance?
  9. Slicks
    Slicks
    from denison tx
    Gauges are cl***ic red dot high beam indicator did not modify dash panel mounted in bezel hole used the 4 5/8 speedo with out bezel not GPS 250 dollars for GPS ouch drill hole for high beam
  10. Slicks
    Slicks
    from denison tx
    chopd top likes this.
  11. Slicks
    Slicks
    from denison tx
    chopd top and JeffB2 like this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    That looks great,it's difficult to modify the 50's Ford instrument cluster and have it appear that it could actually have been done at the factory. HRP
    JeffB2 likes this.
  13. buymeamerc
    buymeamerc
    from s.c.,usa
    great job, man. looks show quality!!
  14. bobss396
    bobss396
    Nice to wire something that is so clean. I had to clean up the back of my stock cluster quite a bit before it went back in, nice when everything works.
  15. Hunter73
    Hunter73
    Very nice! You did a very good job.
  16. Rui
    Rui
    Thats slick Slicks!
  17. Dos Cincos
    Dos Cincos
    Looks great! Nice work.
  18. Slicks
    Slicks
    from denison tx
    Thank's for all the nice reply's i had waited over two years to put the gauge's in the dash panel i just got done rewiring the car so i was waiting tell i did that the panel is a little bit of a pain to get out i had them under the dash before
  19. Jimmy2car
    Jimmy2car
    from No. Cal
    Slicks
    Can you get that Speedo in a mechanical version also?
  20. HOTRODPRIMER
    HOTRODPRIMER
    Who manufacturers the gauges? HRP
  21. Jimmy2car
    Jimmy2car
    from No. Cal
    Dan
    I think they're Cl***ic Instruments
  22. Slicks
    Slicks
    from denison tx
    They're Cl***ic instruments nostalgia vt
  23. Slicks
    Slicks
    from denison tx
    Jimmy2car i do not know it they make a mechanical speedo or not you could call them my speedo works real good just 3 wire's to hook up from trans
