New guy from Maryland
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by carmarc1, Aug 23, 2012.
  1. carmarc1
    carmarc1
    I been snoopin around on this forum and found some dam good info here
    glad I joined. I just got a 55 ford customline and its my first 6 volt car
    never did a 12 volt conversion before . Now the guy I work with says just pop in a 12 volt battery and a 1 wire gm alt and Iam good to go. Is it that easy? Thanks
  2. Hey Carmarc1.....Welcome from Carroll County.
    Murph
    :cool:
  3. buckhog
    buckhog
    Welcome from PA. Not sure on the conversion though. My 56 Plymouth is a 12 volt car. 56 was the first year for 12 volts in plymouths.
  4. Clark
    Clark
    Welcome....the conversion is a little more than that. All bulbs will need replaced...or they will blow in a short time. Gauges will need a voltage drop. Most Fords up to the early 70's used 6 volt gauges. What they used looks like a small relay. Your starter will burn up eventually too. Basically anything that is electrical should be 12 volt or have a resistor to drop the voltage. Wires are fine...as long as they are in good shape.
    Clark
  5. Ranunculous
    Ranunculous
    Hey carmarc1,
    Welcome to the HAMB from western Maryland.
    You'll like it here...
  6. gmstuff
    gmstuff
    Welcome from Elkridge...
  7. lothiandon1940
    lothiandon1940
    Welcome from Southern Maryland. Enjoy your HAMBtime................Don.
  8. butcherted
    butcherted
    from hagerstown
    Welcome from Hagerstown, Md.
    What Clark said.
  9. willys41
    willys41
    welcome from another western marylander
    don't let your car sit to close to Ranunculous he might stripe it with some of his artistic work :)
  10. carmarc1
    carmarc1
    Thanks for the welcomes.
    I gunna work go with the 12 volt conversion, pretty much picked up everything I need today .
  11. Jimbo17
    Jimbo17
    Howdy from the west coast of Florida.
    12 volt sounds cool and good luck with the wiring.
    Jimbo
