Well I am not new, so I'm half right... met a guy last week while I was in NC and he told me that HAMB was the place for car guys or girls, he called it a car man cave on the internet. I could use some help with a project that I am working on hope you can help. I have a 1940 Ford Coupe that I am installing a Ford 8.8 3.73 posi.differinal in from a doner Mountaineer '97 V8 car. I have listed my questions and what I think I want to do, my problem is will it work and how do u do it??? 1. I need to center the pinion gear, it is currently offset, because of the transfer case. I want to drill the (3) pins out that hold the longer axel tube to the third member press the tube out and shorten it (4" I think) re- machine the cut end press it back in re pin it and back weld both tubes to the third memeber. Does this make sense? 2. I want to use coil over shocks (that I can adjust the ride heighth with), with a 4 link of some type and re use the sway bar. Does this make sense, if it does who's shocks and what configuration of "link" set up would you use? I would appreciate your advise, Many Thanks!!!
Welome to teh hamb Steve, this is the intro section and we ain't smart enough to answer questions. 40 coupe are sweet, post the question on the forum and you'll get all manor of advice ok? Welcome again from the Shenandoah Valley, oj
Welcome from the West Coast of Florida. I am not sure about the man cave stuff but you will find a ton of information and people willing to offer advice and knowledge. Hope it works for you. Jimbo
Welcome Steve. Check out the Va. HAMBers section. There are several of us in the area. I'm having a party at my place in Oct. I posted about it in the Va hambers section too. A lot of the local guys will probably be showing up http://www.jalopyjournal.com/forum/group.php?groupid=69
Welcome from Maryland. Good luck going forward with the build-up of that "40 Coupe. Like oj said before, post your queries on the main board. You'll get lots of help there.....Don.
Welcome from Southern Illinois. We vacation in Virginia and I always see some great iron sitting around that would make great projects. Good luck on the project.
Thanks Guys appreciate the hand shacks. I have lived in Virginia for years but was raised (think that's what they used to call it, folks said do this and U did it) central Illinios. So hi to the guy from southern Illinios, too. I will move my question on to the "main Board" Scottb356 thanks for the invitation, after work release I'll take you up on it... Biggeorge, nice paint!!
