New Guy in Buffalo
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by alco2nr, Apr 19, 2013.
  1. alco2nr
    alco2nr
    from Buffalo NY
    Hi folks!
    I have been reading the H.A.M.B. for a while and decided to join the fray. Mostly because I am seeking an opinion about a hand built car project I have been tinkering with off and on for several years. I call it "Spare Parts" 'cause that's what it consists of for the most part. Stuff I had left over from other car projects. Try not to let the description throw you, I'll post images so you can see the end results so far. The ch***is is 2x3 tubing, the floor, trans tunnel, firewall and fuel tank are 12ga boiler plate, the suspension and steering are Chevette, the rear axle and front brakes are S-10 PU, the wheels are 80 Camaro Rallys with 185/60 tires, the fenders (front and rear) are from a '55 Stude pickup, the radiator shell is an old wheel barrow tub, the trunk lid is a section of roof panel from a 47 Nash coupe. The rest of the body panels are hand formed from 22ga sheet metal.
    The first engine I used was a Chevette 1600cc OHC 4 banger set up with a brace of 30mm Mikuni bike carbs on a hand built intake and hand built headers. I have since swapped that out for a '37 Ford V8-60 coupled to the Chevette 5spd OD trans. I have had the car together enough to test drive on the 1/4mi of dead end street in front of my shop (no lights, no gl***, no reg) It's not a race car but it's fun to drive, rides and handles well and sounds Great! The headers are 1 1/4" schedule 40 stainless primary tubes dumping into 48" long 3" dia side pipes. At first I figured I could get away with open pipes. The V8-60 is only 135 c.i.d. and the static compression is 6.5:1- how loud could it be? The first time I fired it I found out! A conversation next to the car when it was running was impossible. I have since added a pair of Harley sportster muffs in the side pipes to tone it down a bit. I'm using a Stromburg 93-E carb which is jetted a tad rich and when I get the engine warmed up it throws flames when down shifting as well. It's Fun! Anyway, here's my dilemma.
    The car still needs a LOT of work to be considered "done" and it's such a Mutt that it doesn't really fit in any particular category of styling. I was just trying to scratch build a car using as much of what I had available and for the least amount of money. (I have less than $3000 invested) So-wadda ya think? Is it worth finishing or should l I just get a Speedway 27 T Track Roadster kit and drop the flattie and 5spd in it? Pics follow.
  2. I'll give $3,000.00 for your project so you'll have a down payment on the "T".;) Keep going with what you have. T buckets are a dime a dozen.
    Yours is unique. Good luck and welcome from Michigan.
  3. Rat.Racer
    Rat.Racer
    from Maryland
    Welcome, that's an amazing build...Keep going!
  4. 1934coupe
    1934coupe
    Welcome from Rhinebeck, keep on going with that project, that is awesome. Keep on going.
    Pat
  5. ct1932ford
    ct1932ford
    Welcome from CT! Love it. And you won't see another one!
  6. paintguy
    paintguy
    welcome from Kenmore NY
