Hi folks, My name is Matthew.... and I'm a Gearhead. (waits for the 'hello Matthew' chorus from the group) I'm currently running a group of projects. my two current headaches are a pair of baby lincolns, a 1949 and a 1950 to be specific. One is complete, and with a carb rebuild and a good cleaning, might actually run. The other... not so much. Still, I've got the sickness.
thanks. now all I need to do is figure out what this weird *** upside down carb is called, and where i can get a rebuild kit for it.
Welcome from No Cal.... post a pic of your carb... these guys are great at Id'ing parts and getting you the help you need
found it. it's a Holley R-597-A. also known as a 885-FF. Mercury used them on the 49-51 cop cars. Lincoln used them on the 'baby' lincolns. Also known as the 'sport sedan' I am blessed with having the actual factory 'big green book'. Also known as '1949-1951 Lincoln and Lincoln Cosmopolitan Ch***is Parts Catalog." even if it is a bit nibbled on, and smells of old newspapers and mouse pee.
Welcome on. You have the big bruisers. I play with the Mercury cars but my OEM manual is blue. I do have a later green cover copy though. I've purchased kits for the Holley 885 from Macks and C&G. Both left a bit to be desired but they worked. It seems like I ended up using parts from both kits the last time I did one.
