Projects New guy steering question
Discussion in 'Traditional Hot Rods' started by Martinbuilt, Mar 7, 2024.
  1. Martinbuilt
    Martinbuilt
    I'm putting a bunch of mis-matched A parts together. All the mechanical brake parts were missing/damaged, so I decided to go with juice brakes. Everything is used, 36-39/wide five set-up.
    If I go with later spindles, I'll need to switch to cross-steer.
    How big a headache is that?
    If I find a late-30's column and box, will it need shortened?
    Any particular years to look for?
    Thanks
  2. alchemy
    alchemy
    Vendors sell bolt on arms that replicate the original upper steering arm for the side steering. Easy peasy.
    Ned Ludd and 2OLD2FAST like this.
  3. manyolcars
    manyolcars
    many people use a 40 steering column and box
  4. Illustrious Hector
    Illustrious Hector
    Are you using the Model A axle? Split wishbones?
  5. Martinbuilt
    Martinbuilt
    Model a axle, unsplit wishbone currently.
    The only reason I started thinking about later spindles, is that the best front drums I have are '36, which require '36 spindles (came with).
    The arms are cast into the spindle, so the suggested bolt-in arms won't fly.
  6. alchemy
    alchemy
    The arm bolts to the top two holes of the spindle. Gives the same usage of the drag link like Henry designed in 1928.
    But I’m not sure anyone makes such an arm for the 36 spindle. You might need to fab your own. Still a lot less work than making a steering box mount for a cross steer box.
  7. Ned Ludd
    Ned Ludd
    If you do as @alchemy suggests everything would work as on a Model A. You'd just have a spare hole on the passenger side steering arm.
  8. Martinbuilt
    Martinbuilt
    I get it, thanks.
    Too many odd parts in my garage. First time out, it's not obvious what direction to go with things like this.
