1952-59 Ford new guy
Discussion in 'Off Topic Hot Rods & Customs' started by 52plymouth, Dec 17, 2009.
  1. 52plymouth
    52plymouth
    i poster a intro once i dont think it came up.ive been a hamb member for a few years just picked up my first ford a 52 customline 2 door ive had a few old cars a couple chevs and a plymouth lookig forward to this ford though.scott
  2. 52plymouth
    52plymouth
    i posted a while back problems i was having it was sounding like carb problems.so i put a rebuilt on motorcraft 2 bbl,my problem is my car wont stay running it has a power booster if i unhook the vac*** line going to the booster is the only way it will stay running.thanks scott
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Welcome to the group! your problem usually happens in the reverse, that an engine will die from a vacuum leak.Any ideas Guys?
  4. 52plymouth
    52plymouth
    it will die in gear or in idle its whenever there is no open vac***.
  5. Welcome mate,i'am no mechanic,I had feul hose line on my brake booster and vacuum line on the dizzy the wrong way and the engine
    was idoling to high.Swapped the hose's in the right places and used
    correct brake hose and i bolted the carby on to tight,loosened the carby so not to tight.The car runs good now.
    That was my 59 ranchwgn 302 clevo,c4.
