New here and could use some advice
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by maddady70, Sep 7, 2017.
  1. maddady70
    maddady70
    Hi, been looking around for awhile and finally decided to sign up. I need some advice regarding some work I have been doing to my 70 Mercury. I added Edelbrock Performer RPM heads and Comp Cams push rods, lifters and flat tappet cam (256H). The question is after the cam break in ( followed all instructions - lube, break in oil, etc.) when I went to install the inner valve springs I noticed one push rod off the rocker and the other in the same cylinder bent. When I put my inspection camera down there I saw that the lifter with the bent push rod had collapsed. So just a new lifter and push rod and redo the break in or are there more problems that I am facing? Any advice is great as this is my first cam swap.
  2. 38 delivery
    38 delivery
    Welcome from ga!!
    Sent from my SM-N910P using Tapatalk
