new member from oklahoma with a 1960 apache10
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by crzy808, Sep 27, 2013.
  1. crzy808
    crzy808
    from oklahoma
    Hey everyone just wanted to say whats up I just started working on my 1960 chevy apache 10 step side. Every thing runs and drives and its automatic. The first thing i will do is switch from drum breaks to disk breaks. would be great if anyone can tell me where to look up these disk break conversion kit thanks in advance.
  2. 1955IHC
    1955IHC
    Welcome from Essex Illinois. :)
    Sent via Western Union Express
  3. crzy808
    crzy808
    from oklahoma
  4. da34guy
    da34guy
    Welcome from Duncan
    Sent from the wooden crank phone in my bathroom
  5. Model T1
    Model T1
    Welcome. Looks like a nice old truck and you are off to a good start. There are lots of kits and parts houses that can set you up reasonable.
    Don't forget to swap to a dual master and replace all lines, rubber and metal. While you are at it replace all fuel lines too. None of this is expensive and you'll be glad you did it.
  6. Ddelrio227
    Ddelrio227
    from Tampa fl
    When you pull that Rochester put a webber on it from Langdons Stovebolt. This guy is the man with these old rides. No offense but better then 99% of the advice you will get from any of us. Oh and use an old mechanic, they know what they are looking for in these old mills.
  7. modelacrazy
    modelacrazy
    Welcome neighbor from MO.
  8. lewk
    lewk
    from Mt
    Welcome! Nice truck!
  9. slammed
    slammed
  10. crzy808
    crzy808
    from oklahoma
    thanks any recommendation
  11. jfreakofkorn
    jfreakofkorn
    welcome aboard ......
    i have had a friend that unbolted a mid 70s chevy truck front suspension. and then installed it in their 65 C10 ....
    or you can go w/ some of the aftermarket opinions that they have ....
    once again, welcome .....
  12. freddychicken
    freddychicken
    from orange ca
    couple places have those disc set ups try ` pol ,cpp ,brothers ,the truck shop all of em have web sites cpp generally has real good products!
  13. Trophydash
    Trophydash
    from Tulsa, OK
    Welcome aboard from Tulsa! First vehicle was a '60 Chevy pick up.....pretty damn jealous over yours!
  14. Gasserman
    Gasserman
    from Tulsa OK
    Welcome from Tulsa ,Gasserman
  15. xwing01
    xwing01
    welcome from the Hoosier state
  16. burger
    burger
    Welcome to the HAMB.
    Those 60-62 and 63-66 trucks are easy to update to "modern" disc brakes and power steering using parts from a 73-87 C-10. Here's a step-by-step article that goes thru the conversion:
    http://www.persh.org/pickup/FrontSuspension.htm
    The 73-87 front suspension is surprisingly good and is cheap and easy to find. I'm sure a Craigslist search will turn up a cheap parts truck or someone parting one out. If that fails, your local junkyard surely has a half dozen of these trucks.
  17. Carolina Man
    Carolina Man
    Welcome from Stillwater.
  18. hankthebigdog
    hankthebigdog
    from oklahoma
    welcome from NE OKLA.
  19. Okie Pete
    Okie Pete
    Welcome from NC Oklahoma.
  20. MaacK
    MaacK
    welcome from Sweden! nice truck you got there..
  21. MiSo
    MiSo
    from Sweden
    Welcome from Sweden! Nice Chevy Apache you have.
  22. 50 Fastback
    50 Fastback
    Welcome from Chicago! Check out Engineered Components, Inc.
    Hot Rod Brakes and Brackets
    P.O. Box 841
    Vernon, CT. 06066
    (860) 872-7046
