Projects New member, new car
Discussion in 'Traditional Hot Rods' started by Husqy510, Aug 21, 2022.
  1. bchctybob
    bchctybob
    Wowee, what a score. Give it a good bath and post some more pictures. As a street racer, I’m sure that those upper nozzles were there to help start it without getting out with a squirt can. My old next door neighbor had a similar setup on his blown gas hydro. Worked great.
    Welcome to the HAMB.
    Mark Grabo, SS327, Algoma56 and 3 others like this.
  2. Chicster
    Chicster
    Welcome and you're gonna git a bunch of advice, You kinda have to weed through them and pick which ones you want to follow.
  3. Husqy510
    Husqy510
    If I was to try and use the Hilborn could I use it with a traditional fuel cell in the trunk? I realize if would require a return line, but would the pump be able to draw fuel? Maybe I could plumb a small fuel pump to those additional injectors and run off that pump until mechanical takes over???
    wicarnut, Tman, SS327 and 2 others like this.
  4. Hollywood-East
    Hollywood-East
    Actually how is the pump driven on this anyway?
    lothiandon1940 and chryslerfan55 like this.
  5. Husqy510
    Husqy510
    The pump is driven off the side of the mag. Enderle is close to my house so I'm sure I could have them go through it.
  6. Hollywood-East
    Hollywood-East
    That would work by the way, A lift type pump to the mag./pump
    SS327 and chryslerfan55 like this.
  7. AHotRod
    AHotRod
    The ultimate Hot Rod ... let the back tires hang out a 1" or 2" and drive it.
    Congratulations on scoring the car, take tons of pictures and keep us posted as you progress.
    Baumi and 41 coupe like this.
  8. primed34
    primed34
    I'm surprised the rear wheel wells aren't cut out. Cool car and find.
  9. Husqy510
    Husqy510
    Thanks again for all the compliments and ideas. The car currently has 29 11.50's on black steel wheels in the rear and 185s on rally wheels in the front. I may go a little wider in the rear, but that's it. I like the ride height and I have no intention of cutting the wheel wells.
  10. Dick Stevens
    Dick Stevens
    If you start a different thread for the build, please post a link on here for the new thread. Welcome to the HAMB, and yes this the place to be! Very cool purchase and yes there are many jealous guys on here!
    pigIRON63 and 427 sleeper like this.
  11. 57Fury440
    57Fury440
    I wouldn't cut the rear wheel wells either. I like your idea of using carburetors to get it going and make it a little easier to handle.
  12. SS327
    SS327
    Injection has been known to work on the street. You said this car was street raced? Do you know if it had been to a track and what times it turned? You should just keep going with this thread. It’ll be much easier for people to find.
  13. Husqy510
    Husqy510
    Here's a short clip of the car running that one of the sons sent me.
    Unfortunately I don't know if it ever ran a timed event and neither did the son. I haven't looked closely but the blower appears to be 1:1, or close to it, so I can't imagine it made a ton of horsepower. On the other hand the car has to be pretty light as it has no floor or firewall, the hood and trunk lid are fibergl***, and it has no door gl*** with plexi quarter windows.
    I probably won't get going on this car for a month or two because I want to wrap up my current project, but I'll definitely stay active on here and keep you guys updated.
  14. Great find. Always good to see another Tri-5 saved. Personally, I am in the no cut wheel wells group as well. Good for you for staying after the car until you got it.
  15. joel
    joel
    Welcome and great find. Might be easier to make a nostalgia drag racer out of it. I'll watch.
  16. ct1932ford
    ct1932ford
    Welcome to the HAMB. Go man go!
    hotrodjack33 and lothiandon1940 like this.
  17. Husqy510
    Husqy510
    That's kind of the plan, but it will have a license plate
  18. Was quite common
  19. chopt31
    chopt31
    LEAVE IT JUST AS IT IS, MAKE IT SAFE AND YOU WILL BE THE BIGGEST ATTRACTION AT THE CRUISE
    Outback, bchctybob, AHotRod and 2 others like this.
  20. chevy57dude
    chevy57dude
    1:1 would probably make 8 psi on that small block. Bet it would indeed make some power!
  21. Husqy510
    Husqy510
    I'm sending the injection and mag to Fuel Injection Interprises. He thinks it'll work for what I want to do.
    I'm also sending the blower out to have it gone through. After that it's just a basic fuel system, front brakes and a cooling system. I have a radiator and I'm leaning towards an electric water pump. I know it's not period correct but I love the simplicity and the fact that I can continue to cool the motor after I shut it down. I was told the block my be filled with cement so I need to remove the current water pump and take a look.
    oliver westlund, slayer, Tman and 6 others like this.
  22. tommyd
    tommyd
    from South Indy
    Welcome and dang! Cool car for sure.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Such an amazing find. What part of California are you in?
  24. aussie57wag
    aussie57wag
    from australia
    That induction is way cool. That will set it apart from the rest. I'd be running that.
  25. Roothawg
    Roothawg
    Great find. Once in a lifetime deal.
    lothiandon1940 likes this.
  26. Rand Man
    Rand Man
    Welcome. I’m a tri-five guy from way back. Have fun.
    chryslerfan55 and lothiandon1940 like this.
  27. Husqy510
    Husqy510
    I'm in Thousand Oaks, about an 1hr north of LA
  28. Budget36
    Budget36
    I used to fly into Burbank and service a company some 35 years ago, in Thousand Oaks. Seemed to be a 45 minute drive? Used to be a great Fish and Chips place there. Be damned if I could recall it’s name, or the Company I went to!
  29. lothiandon1940
    lothiandon1940
    I just read all of this thread. This car is a fascinating piece of street racing history. I completely understand your thoughts on making it more civilized, but damn this thing must have been a blast to watch and drive back in its' heyday as it is set up. Did the Son have any idea what rear gear his Dad typically ran in that quick-change? Welcome to the HAMB. Can't wait to see the progress on your '55.......Don.
  30. Husqy510
    Husqy510
    Unfortunately the boys didn't know much, but the car did come with a bunch of gear sets and the rear cover.
    I hope to keep the car as original as possible, just want it safe as both my kids enjoy going for cruises. I'll add front brakes and a dual pot master cylinder. I'll probably upgrade the cage as well, so my p***enger and I are safe.
