New member with a question for all
Discussion in 'The Hokey Ass Message Board' started by Roberts mole, Dec 10, 2025.
  1. Roberts mole
    Roberts mole
    Hi Guys!
    Looking for answers or opinions:
    I am running a dropped axle with '40-'48 Ford spindles, brakes, backing plates...ETC. The wheel bearings on this set-up are lubricated with a heavy weight oil. What are your collective thoughts on replacing this wheel bearing oil with wheel bearing grease?
    Thanks!
    Toms Dogs, cactus1 and chryslerfan55 like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    I have never heard of wheel bearings lubed with oil. I have a 40 Ford and I use wheel bearing grease. Whoever used oil on yours made a mistake. My 1940 Ford reference book lists Ford Wheel bearing grease M-544 . but you can use any wheel bearing grease produced today. also I am moving this to the main board where more people will see it
    clem, Chucky, lurker mick and 9 others like this.
  3. Rickybop
    Rickybop
    Grease is the word.
    NoSurf, clem, 57Fury440 and 8 others like this.
  4. Tim
    Tim
    from KCMO
    Yeah I’ve never even heard of someone using oil. I’d pull them and clean/pack with grease before I’d drive it again
    nochop, Tow Truck Tom, hrm2k and 3 others like this.
  5. oldiron 440
    oldiron 440
    I’ve been using synthetic wheel bearing grease for the last twenty five years, no particular brand I’ve used quite a few I use it in my grease gun also.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Clean them up and get some wheel bearing grease, they will last much longer with the right product. HRP
  7. Scooterfish
    Scooterfish
    Work the grease into the bearing properly.
  8. Budget36
    Budget36
    Are you sure it’s oil? I can’t see a way to fill it. Maybe a real light grade grease was used and it’s “runny”?
  9. NoelC
    NoelC
    I'm not sayin grease wouldn't work, wouldn't be better or for that matter the same. But I also don't see why what you have wouldn't work as well. Most bearing don't need much cushion, I'm sure that hub when filled to a 1/4 of the way would splash and provide that cushioning and if it's as you say a heavy weight, thick oil, shouldn't be a problem other than watching for leaks. Like a rear axle bearing? They don't get greased?
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Zerk fittings on the spindle caps...of course;)
  11. DDDenny
    Welcome to the HAMB
    Yep, there is a knack to it, not hard, Google it.
    ckh, Tow Truck Tom and chryslerfan55 like this.
  12. Roberts mole
    Roberts mole
    Looks like oil, feels like oil, smells like 90 WT transmission oil or rear end oil. The smell and feel are un-mistakeable. The bearings and spindle shoulders seem to be in very good condition I am just a bit worried that the internal clearance of these bearings is sized for oil and not grease.
  13. SDS
    SDS
    Try it, worse thing that can happen is...
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    there is no such thing as front wheel bearings sized for oil....
    mad mikey, RICH B, NoSurf and 10 others like this.
  15. squirrel
    I expect it will last forever, if you can keep some gear oil in the bearings.
    That's the advantage of grease.
  16. alanp561
    alanp561
    Maybe not for automobiles, and notice I said maybe, but over the road tractors and semitrailers have been using oil for years.
    NoelC, chryslerfan55 and squirrel like this.
  17. squirrel
    Yeah, gear oil will work just fine on tapered roller bearings. As long as it doesn't all leak out and dry up.
    Moriarity, alanp561 and chryslerfan55 like this.
  18. R Sad
    R Sad
    Cl*** 8 trucks use gear oil on front wheel bearings, but they have a gasket sealed hub or bearing cover with a fill plug and fill line on clear plastic cover. Grease is the way to go on your bearings
  19. alanp561
    alanp561
    Yep, you'd have to have some much better seals on cars, but it does work for thousands and thousands of miles on trucks.
  20. alchemy
    alchemy
    It’s gotta be a real pain in the *** turning the car on its side to pour the grease in the hub before you screw the cap on.
    ckh, downlojoe33, alanp561 and 5 others like this.
  21. 51 mercules
    51 mercules
    Never heard of wheel bearing oil for cars? I've been using Timken Wheel Bearing Grease for years. timken.jpg
  22. twenty8
    twenty8
    Do a search on Oil bath hubs. Lots of info available.
    Mainly a 4WD thing. Standard on some makes. Landrover has used them.
    Would be extremely unusual to find anything like it used on any early Ford stuff.:confused:
    Pics would help.
    winduptoy and 51 mercules like this.
  23. Maybe it was a trailer towed drag car.
  24. garyf
    garyf
    3/4 ton truck rear wheel bearings are lubed in gear oil
    NoelC and squirrel like this.
  25. saltflats
    saltflats
    from Missouri
    Maybe it's something like a corn head oil used in seeders.
    winduptoy likes this.
  26. NoelC
    NoelC
    That right there is proof to me. As for filling, most hubs that I've see have small chambers, I don't see a need for lots of fluid anyways. you coat the bearings, add 1/2 an ounce or so and slide it on, the seal in the back and dust cap prevent any leaks. As long at it retains its viscosity, provides a fluid surface, can't see why it wouldn't work?
    I'm convinced.
  27. Tim
    Tim
    from KCMO
    Yeah I mean guys lube is lube just because they’ve specifically said put wheel bearing grease in wheel bearings for the last hundred years that doesn’t mean we shouldn’t make this more complicated than it is. I mean let’s put chicken grease in there my hands are always slick after eating kfc.
    What’s the worse that could even happen? Not like you’d cook it dry, seize the hub to the spindle snap it off and launch the wheel and drum through Atch’s radiator driving down the highway.
    Yeah big trucks and semis use oil, and I’m sure the space shuttle dolly’s use soemthing else. This is an old ford, it uses grease. The end.
    ckh, mad mikey and Moriarity like this.
  28. It come out of oval track (likely other forms of auto racing do it as well), everything around here above street stocks (maybe even some of them) run low drag wheel/axle /hub bearings lubed with oil. The racing stuff is damn near the viscosity of vegetable oil!
    seb fontana and alanp561 like this.
  29. Rickybop
    Rickybop
    Oil of Olay.
    Chicken gravy maybe.
    It'll be fine.
    ckh and alanp561 like this.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    Dammit man, how ****ing specific does a guy have to be around here to keep people from distorting reality... Maybe I needed to say, "I have never seen a 1940 Ford with it's original front wheel bearings that was driven on the street that used oil to lubricate the bearings."
    If some of you guys don't stop saying that oil is ok on front wheel bearings the OP is going to think everything is ok and I don't know about you, but I do not want to be responsible for what may happen when he snaps a spindle off at 70 mph...
    seabeecmc, Rickybop, ckh and 9 others like this.
