1952-59 Ford New Members Read This!!
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Feb 25, 2010.
  1. hooligan909
    hooligan909
    from San Diego!
    well i belive i did an intro but ill do one for here to! Names Drew and im in colorado springs co, just started my 53 kustomline project! this is my first build so im sure ill be spending alot of time on here asking questions like this one, HOW! do you get the damn steering wheel off! i got the horn off then the nut off the stud coming through the wheel but the wheel still wont budge! lol
    thanx!
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    You will need a steering wheel puller to remove it,Harbor Freight has a puller set for around $15 which will also work on harmonic balancers and other things and comes with a varity of different bolts I have had one several years still works great.
  3. raceron1120
    raceron1120
    re: those HF pullers? Get some hard capscrews as extras, just in case. I got one of those kits recently and tried pulling the strg wheel of that old '54 I'm parting out. Soaked the wheel center good with PB blaster and tried pulling it off - it didn't budge. Ended up pulling the threads off the capscrews! Wasn't the puller, it works fine. Just those grade 2(?) bolts don't take a lot of torque. . .
    So I'm gonna get some grade 5 or 8s and next time I hope the PB had time to soak in better, and also hope I don't pull the threads outta the wheel. They can be tough to remove.
  4. missysdad1
    missysdad1
    Sometimes, after soaking and putting a strain on the puller, tapping gently(!) on the puller center bolt will help hurry things along. Use care and common sense :confused: when you do this or you'll end up damaging the threaded end of the steering shaft.
    X2 on Ron's suggestion to replace the standard bolts with hardened ones.
  5. the-stig
    the-stig
    HI, I'm Ken from So Cal. I joined this group about a month ago & guess it's time to introduce myself. I've got a '56 Fairlane Victoria 2 door. I got it with a 312, three speed overdrive, power seat & windows. So far I've put front seats from a '97 Lincoln Mark VIII, front discs from a '72 LTD, rear axle with discs from a '98 Blazer and have a 302 with a 5 speed from an '85 Mustang waiting to go in. Like everyone else in the country I'm waiting for the money to finish it up. When it is done I will drive it everywhere.
  6. turbochick
    turbochick
    Not sure if I did an intro in this group. Name is Tara, from Traverse City, Michigan. Current project is a 52 Ford Crestline Victoria. Was stored outside for a good 15-20 years in the woods of Michigan... She's a mess. Restoring into a traditional hot rod. Currently dis***embled, partially in primer. Working on body work and floor panels now. I'm sure I'll be learning a lot here.
  7. the-stig
    the-stig
    Welcome Tara, I'm pretty sure you did an intro when you joined. Anything new since the pics in your album?
  8. turbochick
    turbochick
    Not much is new yet. I spent the entire weekend sanding last weekend. I will get some updates going this weekend when we start on the metal work and brakes. So much to do, so little time!
  9. Old Rod
    Old Rod
    from Brazil, IN
    INTRO, Been Hamber since 2004, Started this journey mid 50's.
    Last year sold 29 Highboy Roadster that I owned since 1968.
    After 44 years of *******, fenderless cruising couldn't physically
    handle the 29 any more. New ride 54 Ranch Wagon which wife
    and I intend to do a lot more traveling. Also gives us a year round
    driver. Been a great ride just little easier on the old bones now.
    Bob
  10. the-stig
    the-stig
    Welcome Bob, have any pics of your wagon?
  11. Old Rod
    Old Rod
    from Brazil, IN
    stig, pictures of Wagon on Hamb search Old Rod. Bob
