Features New Model A coupe project.
Discussion in 'Traditional Hot Rods' started by skratch, Feb 10, 2016.
  1. skratch
    skratch
    I started building a car last year Oct 2014. It was an old car build that I found from Craigslist. It had a gas welded chop and filled roof with nice original panels , doors , quarters and wheel wells. Model A frame set up for a typical SBC and a Vette rearend ( haha. )
    Just trying to figure out how to use this app.
    I can load pics of the build. If y'all are interested in it.
    kidcampbell71 likes this.
  2. brokenspoke
    brokenspoke
  3. bjinx
    bjinx
    Lets see them
  4. pat59
    pat59
    Show us the pics!:)
  5. AHotRod
    AHotRod
    Post away brother ..........
  6. scrap metal 48
    scrap metal 48
    Model A's are cool.. Let's see it...
  7. skratch
    skratch
    When we bought the car it was fully half *** ***embled with ever 5/16 bolt and everything was painted red. And I mean everything
    ImageUploadedByH.A.M.B.1455205481.904795.jpg ImageUploadedByH.A.M.B.1455205515.557986.jpg
  8. skratch
    skratch
    ImageUploadedByH.A.M.B.1455209785.244892.jpg ImageUploadedByH.A.M.B.1455209813.748280.jpg
    51 Lincoln flathead with a hydro. Placement was a little tough with this small frame and a 845 lbs motor.
  9. brady1929
    brady1929
  10. Model A Gomez
    Model A Gomez
    Interesting choice for a flathead, they were also in the F6 trucks. Not a lot of parts available. Going to take a lot of cutting on the firewall, the engine needs to go back a couple of inches to clear the radiator if it is in the stock position or lose the fan mounting and the double hole bracket on the frame is right in front of the door post. Will require moving the firewall back almost to the door post to clear the distributor and fuel pump.
  11. skratch
    skratch
    Mr Model A Gomez. That's sounds way easier than what I did.
    Haha
  12. I'm a T and A man ,SHOW ME THE PICRURES ! What's the plan ? chop full fender ? keep us posted. Thanks...
  13. skratch
    skratch
  14. skratch
    skratch
    ImageUploadedByH.A.M.B.1455332216.566053.jpg basically the car right after I cut the floor out with the Lincoln motor sitting in the way.
    v8paul, Jet96, kidcampbell71 and 4 others like this.
  15. skratch
    skratch
    Did I mention , ever part of this car was painted red ? And not in a good way.
    1927graham and DBruce like this.
  16. Pete
    Pete
    Scratch!!!! WHERE have you been!
    It's been a long time.
  17. skratch
    skratch
    Pete.
    This new HAMB was beyond me. Trying to post more ....
  18. skratch
    skratch
    ImageUploadedByH.A.M.B.1455644532.632314.jpg ImageUploadedByH.A.M.B.1455644559.583118.jpg ImageUploadedByH.A.M.B.1455644678.349236.jpg
    The new crossmembers and floor structure going in.
  19. rustednutz
    rustednutz
    from tulsa, ok
    Looks like you're starting with a good body. Mine is a true epic rust case, but we'll make it work. You're making good changes.Keep posting pics.
  20. patmanta
    patmanta
    from Woburn, MA
    Is that a 337? BEAST!
    How did you go about the dimpling on that tubing for your X member? I like how you did that.
  21. IronFord
    IronFord
    from NoDak
    I like where this is going.
  22. chaddilac
    chaddilac
    Dang that's holy!!!
  23. skratch
    skratch
  24. skratch
    skratch
    Patmanta yea. It's the 337 cid. It was just drilling and dimpling. Pretty simple. Just time consuming.
    I showed my nephew how I wanted it , he did the rest of the holes and dimples.
    patmanta likes this.
  25. Ryan
    Ryan
    ADMINISTRATOR
    Hey skratch! That x-member is nuts!
    DBruce and Black Clover Custom like this.
  26. skratch
    skratch
    ImageUploadedByH.A.M.B.1455766246.117711.jpg ImageUploadedByH.A.M.B.1455766289.387239.jpg ImageUploadedByH.A.M.B.1455766315.208925.jpg
    Basically the ends and outs of the floor. Straight forward and simple. Clearing the big Lincoln motor and hydro was the only issue.
  27. Mr48chev
    Damn I've driven over bridges that weren't as stout as that subframe. I'll be watching this one close to see if I can pick up some pointers for mine.
  28. skratch
    skratch
    Thanks Ryan. I'm known for getting some nuts.
    Old-Soul likes this.
  29. skratch
    skratch
    That's not what I meant. [emoji52]
    RICH B, Black Clover Custom and Tim like this.
  30. skratch
    skratch
