New one to me
Discussion in 'The Hokey Ass Message Board' started by coilover, Mar 10, 2011.
  1. coilover
    coilover
    from Texas
    Had a 1966 F100 come in that had a sbc installed that looked factory, very sanitary and rams horn center dumps were perfectly placed. It also has a throttle cable set up that must be offered by some supplier but which I have never seen before. It has two teflon or similar type material blocks, one at the firewall and one on the intake for a naked cable to run through. The front of the block on the firewall is beveled and the rear of the one on the intake is the same so the cable can exit and enter at an angle without binding. The unit on the intake can be adjusted vertically and horizontally so the throttle cable and the trans TV cable are in alignment. Anyone seen one of these? I wonder how long one would last till the cable started to saw a groove in the blocks?
  2. propwash
    propwash
    from Las Vegas
    could be a engineered setup by the builder. some folks are much more clever than most of us....not me of course...but most....
  3. badshifter
    badshifter
  4. Fopelaez
    Fopelaez
    Blocks look like Nylamid to me, there are several kinds of nylamid and some are "self lubricated" they will last a lot and are stronger than one can imagine. It is said to be the steel of plastics, very light weight and very machinable. You can buy it at your steel supply. Hope this helps.
  5. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    just looks wrong, kinda cheap & half-***ed.
  6. supervert
    supervert
    i thought the same thing but, it was more because somebody put a sbc in it:eek::D
  7. shinysideup
    shinysideup
    from ruskin, fl
    Funny you thought that rigged **** was store-bought,HA!
