Projects New Project 32 Pickup
Discussion in 'Traditional Hot Rods' started by mprice, Feb 17, 2025.
  1. mprice
    mprice
    from Washington
  2. Tim
    Tim
    from KCMO
    Nice!
    Stogy likes this.
  3. krylon32
    krylon32
    from Nebraska
    Great start. I'm driving my 5th deuce truck.
    Stogy likes this.
  4. pantodd74
    pantodd74
    Very nice! What kind of bracket did you make to lift the body with the engine hoist?
    Stogy likes this.
  5. Stogy
    Stogy
    Looks much happier...I'm sure you are too!! That was fast...:D
    Spring is gonna be pretty special this year...
    brady1929 likes this.
  6. Good looking truck!
    Stogy likes this.
  7. Notice the big 4x4 beam up against the top of the door areas.
  8. pantodd74
    pantodd74
    I can see the 4x4 I was referring to the metal bracket and how it's attached to the hoist.
    Stogy and Algoma56 like this.
  9. mprice
    mprice
    from Washington
    Use the chain bolt hole attach 6 inch metal strips on each side of hoist connecting to a pivot point on 4x4 bracket
    SPEC and Stogy like this.
  10. Stogy
    Stogy
    If you could you take a pic of the setup without the cab and share, that would bolster the explanation quite nicely...
  11. Ducbsa
    Ducbsa
    from Virginia
    I'm sure it was carefully balanced before lifting very high.
  12. tarheelrodr
    tarheelrodr
    Made a long U channel from 2x6s and a 2x4 with all thread bolts it to hoist arm at chain hole to pivot. Rachet strap to secure it. Worked well for a one man show. Many times actually. PXL_20231013_173157539_Original.jpeg
    akoutlaw and Algoma56 like this.
