New Project: 63 Olds, need 394 engine
Discussion in 'The Hokey Ass Message Board' started by Charlie Jones, Nov 4, 2011.
  1. Charlie Jones
    Charlie Jones
    from Apopka FL.
    I just bought a nice rust free 63 Olds 88 from NM. Only problem is there's no motor or trans.
    I want to go back with a 394 Olds engine, with a tri-power manifold ? and put a 4 speed behind it.
    I'm looking for the following items:
    1. 61-64 Olds 394 engine in rebuildable condition.
    2. Clutch and brake pedals and linkage for a stick shift 63 or 64 Olds.
    3. Bucket seats for a 60-65 full size GM car.
    4. Engine adapter bellhousing for a 49-64 Olds engine to a 55 and up Chevy trans.
    5. Olds 394 manifold drilled for tri-power carbs. (Small center and big end carbs)
    6. A set of 60-66 Pontiac or Olds tri-power carbs in rebuildable condition.
    If you have, or know the whereabouts of these, please send me a PM.
    Thanks, Charlie
  2. lowkroozer
    lowkroozer
    Contact Ross Racing Engines In Niles Ohio 330 544 4466 They are Olds spe******ts and have a wealth of knowledge.I am sure they can help you out .Tony ,one of the owners is a HAMB member.He goes by Goatroper on here...............
  3. Charlie Jones
    Charlie Jones
    from Apopka FL.
    Thanks for the tip.
  4. GOATROPER02
    GOATROPER02
    from OHIO
    I prob have everything you asked for in stock
    Give me a call
    Tony
  5. Charlie Jones
    Charlie Jones
    from Apopka FL.
    Found a core engine, still need all the other stuff. Thanks.
  6. tankwilson
    tankwilson
    not sure the size but i just pulled a motor/trans and rear end out of a 61 olds super 88 at work. Also have a few other parts off the car. Still need it??
    Thanks
  7. Sssingo
    Sssingo
    from London
    I have a full car in primer - no rust whatsoever. sorry to hijack post but if anyone is interested - pm me. Its in the UK and it's a lowrider with displacement rams under the trunk
  8. You don't need a 394 I need your body. Hell between us we got a whole car. :D
    Body looks real solid, I hope you and tony work something out. :cool:
  9. bobss396
    bobss396
    I recall that Pontiac stick parts (pedals, etc) practically jump in by themselves. This was what someone used when I looked at a '62 88 many years ago. I don't believe I ever saw a '61-64 full sized Olds with a stick set up, but I'm probably wrong.
    Bob
  10. Nice looking Olds project you got there. I'm jealous
