*New Project help! LT-1 With Blower!!**
Discussion in 'The Hokey Ass Message Board' started by BtDt, Jul 13, 2007.
  1. BtDt
    BtDt
    Looking for advise and how to's I have a 1996 Buick LT-1 engine, complete with computer and all the running gear, runs great! want to use it in my secret wepon:cool: ..any one on her know about placing a blower on this injected 5.7 lt-1 motor? How to? what blower? pit falls? any info would be greatly appriciated
    Thanks in advance
  2. flatheadpete
    flatheadpete
    from Burton, MI
    Mmmmm....Procharger, prolly a P1SC. Hot cam, LT4 intake, fast burn heads. Gonna want an intercooler for that big *** blower. Prolly a bigger throttle body, too.
  3. wvenfield
    wvenfield
    You are going to need someone to reprogram the computer. If you can't find anyone PM and I'll send you the info on the best at doing that.
    He likely can answer all your questions also. There are complete supercharger kits for this engine available. Unless you can make your own you are going to find that suitable headers are stupid money. If you have alot of clearance you can use F-body headers which are cheaper.
  4. BtDt
    BtDt
    had PCMforless do a re-program already but will more than likely need to be done again once the supercharger is on..Im sure injector size will be an issue too..wonder if there is a complete kit to do this and i just havent found it?
  5. wvenfield
    wvenfield
    Well I see you have already found who I was going to suggest. lol
    I don't recall what all the kit had but I can't imagine that the injectors wouldn't be included or at least note which ones to use as no, the stock ones won't be suitable.
  6. BtDt
    BtDt
    sounding like a this winter project..done with the 53 chevy think i'll move on to the buick
  7. BradH
    BradH
    Check out the C4 section on www.corvetteforum.com. There is a forum dedicated to supercharging, turbocharging and putting nitrous oxide on LT series engines. I like to go there and think about nitrous oxide on my LT4 Corvette. :)
  8. pprather
    pprather
  9. Boynamedsue
    Boynamedsue
    Use a paxton on the LT1. Youll need the Lt4 intake for sure the stock LT1 doesnt flow very will. also up the fuel injectors i think stock are 18 or 22 im not sure 26 or 25 will be good. intercooler definately. get a boost controller to help with fuel and timing management. you will need the computer reflashed for the new injectors and ignition. put an LS1 cam in it they work great for blower applications, and maybe a good set of headers something ceramic coated to help with the incresed heat from the raised compression.
    So: LT4 intake, LS1 cam, headers, ignition system with boost controller, intercooler (air-to-air), fuel injectors, computer reflashed. with all this being said and done with 7-8 Psi you should be nicely into the mid 500 Hp range.
  10. Appleseed
    Appleseed
    Yes. Yes we are. Really, there is alot of good stuff on this site.
