new project my 34 , 5window gets under way
Discussion in 'The Hokey Ass Message Board' started by bobbooth, Dec 6, 2011.
  1. 60'shotrod
    60'shotrod
    Yeah Man, I'm mulling it over.
    Nick.
  2. Besty34
    Besty34
    I have not got the banjo axle but removed all its bracketry onto my axle ,im not sure what measurement you want ,is it the distance from the axle centre line to spring centre line at the at the shackle ?
  3. bobbooth
    bobbooth
    from limeyland
    Yes mate that will do, axle centre line to shackle centre line will give me an idea of the ball park figure;)
  4. general gow
    general gow
    MODERATOR
    Bob, the axle center line to spring center line is the same on rearends 1932-1948. however, since 32, 33, and 34 has the "compound curve" spring, the hangers are shorter. so, with a stock spring on a later rearend, you have effectively pushed the rearend forward.
    i am using a 1948 rearend and spring in mine, and have shaved the spring to conform to the curve in the rear crossmember.
    if you want to use the stock spring, you'll also need to use 1934 hangers on your rear too.
    hope that helps.
  5. Idaho/Dave
    Idaho/Dave
    from Idaho
    the spring hangers on a 33-34 rear end are shorter than the later rear ends,so the center line of the rear end to the center line of the spring shackles . is not the same as the later rear ends, also the 34 spring hangers have a cant to them, you would have to heat and bend them to fit a later spring, best bet would be use a 37 to 40 rear end and grind the straight later spring to fin the curved cross member, I believe the 41 through 48 rear ends are wider in width, Dave
  6. general gow
    general gow
    MODERATOR
    ah, right, dave. good call. center line of axle to center line of spring are same. not shackles. sorry for the misdirection. i'll correct the post above too.
    i am doing as you suggested, grinding the spring to fit the curved cross member. i am using a 48, and it has taken some grinding. but it's working out.
  7. ss34coupe
    ss34coupe
    Idaho Dave has it right. You should use a the spring that went with the later rearend, and can either grind a bit off the centre portion that fits into the rear crossmember (a 39-30 rear spring is about a quarter inch too wide to fit into a 34 crossmember - or modify the crossmember to widen it that quarter inch - that is what I did on my 33 coupe with a 40 rearend.
  8. bobbooth
    bobbooth
    from limeyland
    Thanks guys that there is the info that i needed, much appreciated :). I will get grinding on that that spring;)
    I had a set of 34 axle spring mounts that i cut off the axle under my roadster as I had gone spring over but i ended up using them as the shock mounts
  9. daly425
    daly425
    Hi Bob the coupe is a further on than lot than I thought and looking good I want to look around you workshop I was speaking to Archie and he is thinking of selling his coupe
    Brian
  10. BOP-Nut
    BOP-Nut
    Moving along very nicely. Great work on the floor and patch panels.
  11. marman1950
    marman1950
    This car is a++++, love this thread and keep up the killer work!
  12. scotrodder
    scotrodder
    from glasgow uk
    Hi Bob,
    Wee Brian sent the link to your build and i must admit you are fairly cracking on at a good rate, the car looks excellent even if it has too many windows. Wish i had your talent with the metal work, its going to be a real hotrod.
    Like Brian says, i would like a rumage through your work shop too, lots of interesting stuff going on in the background, we are always looking for some where to stop off/visit on the way down to the swap meet, but keep in mind we do come on m***.
    Cheers
    Brian
  13. bobbooth
    bobbooth
    from limeyland
    Well i haven't got that much done to be honest what with the ****ty weather being snowed in on the days i go down to the unit, and also the fact that I have become a Grandad to a beautiful baby boy this week!!!!! and i'm loving it.
    I got some work done though,When i used the coupe door tops and the 4 door bottoms where they lined up didn't if you catch my drift so just relief cut them and back together but it is one job out of the way
    I also got the rear quarter patch panels in that I made
    and the not so good fitting lower panels in which seemed like an age to fit
    I then made the inner slam panel
    and got the rear sheet metal all ****oned up with the inner panels i did earlier.
    I had to repair the trunk hinge mounting area as i had to tear out the deck lid as it had seized solid, but at least its done and working correctly.All the doors shut nice and latch good, so does the screen. Body wise all thats left is to cut out all the **** below the rear window and repair /make the inner front door posts and deck lid then the body can come back off while I get on with the ch***is, which is the next big step.
  14. Dammit man! Nice work! And congrats on the little 'un.
  15. Inland empire hot rods
    from so cal
  16. tbauer
    tbauer
    Congratulations grampa! Your work on the car is inspiring. Do you have another car your measuring from or are you doing this great work by eye ?
  17. Rocky
    Rocky
    Classified Editor
    Well...you're making a lot more headway than I am with mine but I'll be back on it tomorrow night. Congrats
  18. 32fivewindow
    32fivewindow
    from USA!
    Nice work, maybe this will give me some inspiration on my 33 and 34. Maybe I missed it... flatty?
  19. bobbooth
    bobbooth
    from limeyland
    Thanks
    Thanks
    Thanks yes i did take some measurements from another car but to be honest i took templates of what i could before i cut it all out and just worked it all out from there, ha ha a lot more thinking than doing i can tell ya that;)
    cool be good to see some updates
    Yes a flatty it is ,39 trans 39 rear end
  20. nitrohonkey
    nitrohonkey
    Great work...inspiring!
  21. daly425
    daly425
    Congratulations Bob :)
    When are you starting the tot rod
  22. mikeallcars
    mikeallcars
    Good luck with your project . I have a 33 ford Rat Rod . Keep us posted on your project .
  23. 40Standard
    40Standard
    from Indy
    amazing work! keep the pics coming
  24. bubba67
    bubba67
    from NJ
    My god, Bob, she's really coming along ! I'm inspired to go out and start looking for another Model 40 !
  25. KustomCars
    KustomCars
    from Minnesota
  26. awesome project!!!
  27. bobbooth
    bobbooth
    from limeyland
  28. bobbooth
    bobbooth
    from limeyland
    Hi Timo, how's it going ...
  29. TomT
    TomT
    Really inspiring metal work - subscribed!
