Projects New Project - The 3B Speed Shop 34 Coupe
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Feb 12, 2021.
  1. the-rodster
    the-rodster
    The rake is about where I want it.
    BigJoeArt, Tim, WC145 and 13 others like this.
  2. the-rodster
    the-rodster
    I had to set the grill out front and take a look.
    BigJoeArt, Tim, WC145 and 16 others like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Rich, I lake a few others totally missed this thread, but Man, you have done a incredible job!
    My hat is off to you, keep at it my friend. HRP
    Thor1 and Stogy like this.
  4. Stogy
    Stogy
    @the-rodster, I like the way you make a dream a reality...or maybe its a vision...whatever it is its really ticking all the boxes...thanks for sharing the extensive and impressive journey...;)
    brady1929 likes this.
  5. flamedabone
    flamedabone
    Nice work on the rear spring deal. It is hard to get that right the first time. The profile shot is rad, ***s and gnarly, by the way.
    -Abone.
    Stogy likes this.
  6. B.A.KING
    B.A.KING
    you da man!! going to shades?
    Stogy likes this.
  7. ss34coupe
    ss34coupe
    That is perfection! Keep up the good work.
    Stogy likes this.
  8. the-rodster
    the-rodster
    On the fence, you?
    Stogy likes this.
  9. Straight Axle Guy
    Straight Axle Guy
    Did the build stop?
    Stogy likes this.
  10. B.A.KING
    B.A.KING
    I know they had some storm damage from this past Friday.
    Stogy likes this.
  11. A Boner
    A Boner
    Bump
    Stogy likes this.
  12. the-rodster
    the-rodster
    Dang, I haven't posted updates for six months.
    I've been working on it everyday, but it doesn't show it.
    Next was the front suspension, and it took forever to get the way I wanted it.
    Stogy and Thor1 like this.
  13. the-rodster
    the-rodster
    Then position in front crossmember.
  14. the-rodster
    the-rodster
    I played with the number of springs and the spring arch to get it where I wanted, and welded the perches though the bones.
    Tim, Stogy, A Boner and 3 others like this.
  15. the-rodster
    the-rodster
    Next up, the grill.
    I won't lie, I spent 2 weeks on this, it was a pain.
    The starting point.
    Stogy, A Boner and Thor1 like this.
  16. the-rodster
    the-rodster
    Bars cut out, shell cut in half.
  17. the-rodster
    the-rodster
    I narrowed the top piece three inches, just enough to eliminate the fill hole.
    Thor1 likes this.
  18. the-rodster
    the-rodster
  19. the-rodster
    the-rodster
    Next, I narrowed the bottom shell three inches.
    rod1, Stogy and Thor1 like this.
  20. the-rodster
    the-rodster
  21. the-rodster
    the-rodster
    The top piece looks pretty good, width wise.
    rod1, Stogy, Thor1 and 1 other person like this.
  22. the-rodster
    the-rodster
    Then I needed to figure out how much of a chop the grill would get, it needed a lot.
    I settled on 4 inches.
    Stogy, A Boner, Thor1 and 1 other person like this.
  23. the-rodster
    the-rodster
    After taking four inches out of the middle, I knew this was not going to work unless I bolted it all down to a to the workbench, and added a strip down the middle to keep the bars aligned.
  24. the-rodster
    the-rodster
    Now I just need to get this mess to fit back in the whole.
  25. the-rodster
    the-rodster
    I worked in sections, starting at the bottom, carefully cutting to size and tig welding.
  26. the-rodster
    the-rodster
  27. the-rodster
    the-rodster
  28. the-rodster
    the-rodster
  29. the-rodster
    the-rodster
    Everything tacked, time to finish weld.
    Tim, Stogy, A Boner and 5 others like this.
  30. the-rodster
    the-rodster
