Hot Rods New project
Discussion in 'The Hokey Ass Message Board' started by Scott, Oct 29, 2008.
  1. Scott
    Scott
    My model A has been gone for 3 weeks and I needed something to work on.
    I believe its an early 20s dodge. If anyone can pinpoint the year and model I would appreciate. going modified style with it it:D[​IMG]
  2. 067chevy
    067chevy
    I like it. Looks solid. Whats the plan?
  3. Strange Agent
    Strange Agent
    Looks decent enough. What are you going to do?
  4. 25 Dodge.
  5. Looks like it was a 1916 -19 phaeton.
  6. Scott
    Scott
    Im going to do a modified style. I had already tacked up a T style frame
    I have a mopar box for cowl steering Ladder bars, hairpins, f100 brakes, 37-41 spindles. I have a front buggy spring for the rear unless I go with coil springs
    Rear has a 7-1/2" kick in the rear Im going to kick up the front Dan Collins style. I think I will channel this one.
    I also have TONS of questions to ask:rolleyes:
  7. Scott
    Scott
    Decided to channel the body today. Got rid of a lot of old metal ie. the floor.
    Found a bunch of bondo in the back. It appears to be a late 60s or 70s mold job. Anyway the filler seems to have preserved the metal. I guess a sub floor will be next
  8. low budget
    low budget
    from Central Ky
    It could be the front section off a dodge brothers 4 door touring car.
  9. CGkidd
    CGkidd
    Concure 1916-1919 touring body.
  10. FRITZ
    FRITZ
    1922? look just like what Roth used as a base to build the "Outlaw"
    FRITZ
  11. skwurl
    skwurl
    looks solid
  12. Scott
    Scott
    Started on sub floor today. Ill tie this into the body and firewall as it progresses.
    Note: steel is getting expensive:(
  13. noboD
    noboD
    Yes, it's pre-20 because of the verticle windshield, post '20 slanted back.
  14. Very kool Richard Riddel built one that was featured in Hot Rod Magizine as Underbudget underslung one of the best rods i've seen very kool check it out
  15. Scott
    Scott
    I put it on the floor today and mocked up some of the suspension.
    Im using the 40 front spring on the rear end. I have to figure where to set the Ladder bars. My concern is if I set them under the lowest part of the frame, that they will bottom out. So I will set them to just clear the frame before the kick up. Front is pretty self explanatory, I will pie cut just in front of the firewall. about 5 degrees will give me about 4-1/2 to 5" at the front cross member. Im going to cut out 2" out of the rear axle housing to center the rear end.
  16. chaddilac
    chaddilac
    Nice, when you get the wheels on it you'll really get excited!!!
  17. sko_ford
    sko_ford
    looks good. i really am startinh to pull twards these off brand(non ford) bodys. whats your motor plan?
  18. Scott
    Scott
    I found another 283 locally from a 66 elky. 42 years old and still Standard bore!!!!!. Be a while before rebuild but Im glad I got it:)
  19. 41 Dave
    41 Dave
    Scott, Your new build is lookig good. Keep us posted as you progress !
    41 Dave
  20. Scott
    Scott
    I brought the rearend up to approx height with tires. Mocked up ladder bars.
    I had to push the rear end forward to avoid possible contact with the rear spring. Ill have to fab some spring perches. Critiques welcome:)
  21. Lookin sweet!! Should be awesome when done.
  22. T.W.Dustin
    T.W.Dustin
    cool build on the old MOPAR - looking forward to updates :cool:
  23. Scott
    Scott
    Today I swapped some stuff for a Muncie 3 speed It will go perfectly with the 62 truck bell housing I have in the rafters
    The code tells me its from December 17th 1974. with a 3.03 first gear
    I love hotrodding
  24. Scott
    Scott
    Some spring perches. 1/4 flat stock and 1x3/4 DOM
  25. 067chevy
    067chevy
    looks like its coming along.
  26. Scott
    Scott
    Hopefully I can get more of the suspension done this weekend
  27. JLasvegas
    JLasvegas
    from Skin city
    pretty cool to see it coming together, keep the pictures and updates coming
  28. Scott
    Scott
    Yesterday I got my batwings from speedway along with a few other items so I decided to mock up the front end (like I have a choice)
    Next is the rear suspension
    The spring perches 1/4 inch plate and 1x3/4 DOM
    squaring up everything and tacking with a small gap for penetration
    tacked in some gussets 1/4 inch
    Every thing is square
    Here it is under the frame
    I set the pinion angle at 0 degrees for now
    I can see major body modifications in the future!!
    Thanks for looking:)
  29. Scott
    Scott
    Mocked up Ladder bars/hairpins. I know its not optimal,but its what I have for now.
    Maybe I can add a torque arm. Chime in with thoughts please
  30. Scott
    Scott
    Today I did some work to the firewall. I'm going to do swing pedals with the Chevy brake/clutch master. I decided to back up the firewall with a piece of 16 gauge. The firewall was totally molded with bondo. I was originally going to leave the Bondo kind of as a homage to the 60s or 70s when it was probably done. But that went out the window:rolleyes:. Took about an hour of burning and grinding to get the finish off. One good thing about the body filler. It really preserved the steel.
    Ill tack it together this weekend, and get going on a swing pedal mount
