Technical New Tach, Location ideas?
Discussion in 'Traditional Hot Rods' started by 64polarbear, Apr 3, 2015.
  1. Side
    1 vote(s)
    16.7%
  2. Top dead center
    5 vote(s)
    83.3%
  1. 64polarbear
    64polarbear
    I purchased a tach for my polara. I can't decide if I want it on the side (as pictured below), or straight up dead center top on the steering column. In the pic, its not blocking any other gauge. On the top center, it will block the odometer and kinda stand out. Opinions??
  2. The 'let's accessorize it' crowd put on the side of the column, the street racers put it on top, the real racers screwed it to the top of the dash! LOL!
    loudbang, 56don, 69fury and 1 other person like this.
  3. LMFAO when I read the ***le my first though was. "where the sun don't shine." :D
    When I can pull it off I put mine on the dash with a soda cup from my favorite drive in stuck over the back of it. That said a tach is not of much value if you can't see it so I am going to vote for up top on the column, if on the dash or hung from the top of the windshield won't work for you.
    LOU WELLS, 69fury and 64polarbear like this.
  4. 69fury
    69fury
    from Topeka
    if you're not really going to use it, not really going to see it easily when it counts, then what's the point- put it straight up or on the dash. -rick
    64polarbear likes this.
  5. Rick
    I haven't had a fuel gauge that worked in ages, so I guess seeing the odometer might be pretty important to me. I guess that being the case I might want it over to the side. Or I could just fix my fuel gauge. :D
  6. 69fury
    69fury
    from Topeka
    Is fixing your fuel gauge traditional? I guess that depends on how long it's been broken :)
  7. chopper99
    chopper99
    My buddy (a drag racer) always said "if you have time to watch a tachometer, your car is too slow".
    Drunk Man likes this.
  8. LOL or you shift too slow. :D
    I have a tendency to drive my cars by the tach instead of the speedo, but when I am getting busy I am usually trying so hard to not bang into something that the tach is the last thing I am looking for. :D
  9. mad mikey
    mad mikey
    If you want to use it, read it while banging gears. Mount it on the dash in sight while doing so. If you just want a tach cuz its cool put it anywhere you want.
  10. i say the tach is for setting timing. if you are really racing this car put it were you want. you shouldn't be looking at it going down the track. the hot set up is a shift light small or large mounted dead center of you. mount it at the chrome strip at the windshield. you never have to take your eyes off the road or track. its so simple. it lights up you shift.
  11. Road Angels
    Road Angels
    You only need one
    Tach its Called your EAR
  12. Road Angels
    Road Angels
    Oh yea dont forget the old **** Tach, when your **** is not being pushed back in the seat its time to shift
  13. As has already been said...if not on the dash, then top center.
    If you are going to use it, you need to be able to see it.
    PnB, just top up with fuel every three days! ;)
  14. cometman98006
    cometman98006
    I put mine on the side like you show. Since my speedo is 20 percent slow I use the tach a lot for speed and it is convinent for me there. Got to get the right speedo gear in it.
  15. But its only 25 hours from my house you yours, I may run out of gas before I get there. Guess I better buy AAA :D
  16. Hdonlybob
    Hdonlybob
    I voted Side...no particular reason....
  17. 64polarbear
    64polarbear
    I ended up with mounting it as pictured. My fuel gauge is currently in operative so I am using my odometer until the fuel gauge issue is solved (possible bad ground). I use my tach so I can gauge how my vehicle is running, shifting, etc. on the side where I mounted it, it's not hidden or obscured by the steering wheel as some are ***uming.
