new wheels, pic inside
Discussion in 'The Hokey Ass Message Board' started by ma70tt, Mar 26, 2009.
  1. ma70tt
    ma70tt
    picked these up off a customer for $20. what are they? no discernable markings on them anywhere. the guy says they were on his grandfathers '66 fastback mustang years ago. im thinkin' this is the start of my model a project right here.
  2. fab32
    fab32
    Neat looking wheels. Did you just get two or a whole set of four? If just two these would make super rears and look for something gasser style for the front. BTW, what size are they?
    Frank
  3. ma70tt
    ma70tt
    just the two rears, theyre 15x9". thats exactly what i was thinking, pair if somethin' skinny for the front, and some pie crust cheaters or maybe a whitewall cheater on this model a roadster i have. whatever i end up doing it will be crazier than my '52 4100...
  4. ma70tt
    ma70tt
    nobody knows what these wheels are?
  5. dickster27
    dickster27
    from Texas
    They look to me like an early ET wheel, like an ET III, especially if they have a little dip in the bottom of each spoke. If that fit on a Mustang then I would say the bolt pattern is 4.5"-4.75" with the elongated slots.
  6. ma70tt
    ma70tt
    ill wash 'em up and get a better pic up today.
  7. Great score. Certainly ET style wheels.
  8. alchemy
    alchemy
    For original ET's on the front, you'll find a dozen 14"ers for every narrow 15" size you find. But good luck searching.
  9. Daddyfink
    Daddyfink
    Any markings on the back of them?
  10. rainman1958
    rainman1958
    you know their aftermarket because unilug. Look like ET's to me also
  11. helmsville
    helmsville
    i like the billet wheel's that have the flames cut into the billet, your's suck!-------not realy those are whayso cool.
  12. Mickey Thompson.......
  13. Jeem
    Jeem
    Alliance Vendor
    I'm guessing Mehelich wheels used these as there basis.
  14. redlinetoys
    redlinetoys
    from Midwest
    Sweet score!!!!!!!!!!!!!!
  15. DRUGASM
    DRUGASM
    i wonder if there would be any markings if you un/dis mounted those tires.
  16. r0ckstarr
    r0ckstarr
    from Houston
  17. HotRod33
    HotRod33
    wish I could find a set of those......
  18. Sure they're not 14's? They are definitely ETIII's but with that window style they would be the 14x7's - the 15's had a more square window. Having said that, I think I remember hearing somewhere that Wheel Centre did build these in 15" with this style window but in VERY limited numbers - confirm the size for us . . .
    Steve
  19. ma70tt
    ma70tt
    15x9or 9.5" no markings whatsoever. markings are a poss inside. wont know till i dis mount them.
    def not those mickey thompsons tho.
  20. 56truk
    56truk
    from piqua,ohio
    Look like Ansen brand that I ran in the early 70's.
  21. Look like ET-III's with the washers. When the washer hole is in the center the bolt circle is 5 on 4.75. Thwe washer with the offset hole makes 5 on 4.5 on e way and 5 on 5 the other way. If the wheels are 15" ET's they will be 15X7.75 or 15X8.5. The latter size is extremely rare. Remember, you measure wheel width inside the beads, not outside. Backspace on the 7.75" width wheel is 3.75, on the 8.5" wheel backspace is 2-15/16"
    Charlie
