1952-59 Ford New Windsheild Friday! Hints advice?
Discussion in 'Off Topic Hot Rods & Customs' started by reedo, Mar 31, 2011.
  1. reedo
    reedo
    Hired a gl*** guy thats done other work for me, but not on a 1954 Customline. What are some tricks to working with the chrome trim? I have removed the upper sections on my parts car and dont want to damage any of the strait pieces i have!
  2. streetdreams
    streetdreams
    Read the manual closely for your model. Some of the trim is installed to the rubber seal before the window is installed. Also, if you're going to ever do your headliner, do it now. The headliner is installed before the windows are. I soap the seal up good before installing and use the string method, but your gl*** guy probably knows that. Good luck.
  3. genosslk
    genosslk
    Hire the gl*** guy again.... if he breaks the gl***.... he replaces it!
  4. Retro Jim
    Retro Jim
    Yep , Hire a pro to do that ! Worth every dollar !
    Jim
  5. reedo
    reedo
    Thanks guys, I know when to ask for help! I take it that we ***emble gasket-gl***-and moulding, then install.....correct??? With lots of hot soapy water!
  6. streetdreams
    streetdreams
    All depends on how the manual says to install. A little soapy water in a squirt bottle is fine. With a guy at each corner pushing lightly as the string is pulled and a guy on the inside pulling, it's a 2 minute job.
  7. vein
    vein
    lots of muscle with TLC! I installed my front window and wow its alot of work! I paid someone to install my rear window because of the curve of the gl***.
  8. streetdreams
    streetdreams
    Really never had a problem with them. Are you pulling them in using a small diameter cord?
  9. Retro Jim
    Retro Jim
    If you don't like the string method there is a nice tool made with a ball on the end to install the new gaskets . I have one but haven't had the change to use one yet Well made from Eastwood .
    I am going to let a guy in the next tow do mine . He has been in business for a very long time and has done many curved old gl*** . He charged $75 per window . So I figured $150 to do the front and back will be a great deal !
    Jim
  10. streetdreams
    streetdreams
    The bad part about any tool that is hard is that there is the potential to jam or get tight as you pull. If so, something has to give, usually the gl***. Everybody has their own method. I learned the string method and a couple other tricks from my father -in-law, who was a glazier and had a gl*** shop for 40 years. He put thousands of curved gl*** windows in back in the day.
    If you pay to have it done, that's fine too.
  11. reedo
    reedo
    Gl*** went in Great! Really better with two people and yes Rope method works perfectly with the other person applying pressure on the outside working your way around. installed window seal and chrome on new gl*** some tape and set the window.....I will try and post some pics soon.
    Thanks for all the input guys. Today is a Feelgood Friday!
  12. streetdreams
    streetdreams
    I love it when a plan comes together..............
  13. Retro Jim
    Retro Jim
    Glad to hear it turned out great for you ! I have seen it done on TV before and read many times on how it's done but if I wanted to do it I would like to have tried it on something smaller than my windshield . I can build you an engine as you want , do some body work , rewire you car and install another rear or new front end but I have never tried the windshield install yet and would rather pay a pro to do it . I have done many side flat gl*** and curved gl*** in the 1970's and 80's but never did a curved windshield and they are to costly to replace on because I messed up someplace with too much pressure .
    Jim
  14. riskybiz
    riskybiz
    Reedo I hope you used a good quality packing seal (material) around pinch weld. Before you installed windshild. If you only installed gl***/rubber seal without some you may find out that your windshield will leak.:eek: I install gl*** at the bodyshop I work for. Just my 2 cents.
