Technical Newbe
Discussion in 'The Hokey Ass Message Board' started by Steve Duleck, Jan 27, 2019.
  1. Steve Duleck
    Steve Duleck
    Hi all,
    Been a long time reader here, and I need some help with a 283.
    Early 60's 283 rebuilt long block
    mild cam, Q jet, Hei
    I'm braking in this motor for a friend on my engine stand.
    Starts and runs good...
    But when I rev it and let off it dies every time.
    the carb, fuel pump ,distributor all came off my 350 and was working fine.
    I tried two different 2 bbls, 3 dizzys Hei and points, and I still get the shut off after revin' it.
    Compression 150-138
    valves are good at 3/4 turn Hydo
    I can't figure this out.
    Any help would be great.
    Cheers
    Steve
  2. Rckt98
    Rckt98
    Welcome from another kiwi.
  3. timwhit
    timwhit
    It does sound like it is starving for fuel?? PM squirrel.
  4. King ford
    King ford
    from 08302
    Does it idle before you rev it ?...do you have a flywheel on it or just a flex plate?...if you don't have enough " inertia " or " rotating m*** and a relatively lean idle mixture it will most likely do that...
  5. stillrunners
    stillrunners
    from dallas
  6. Vacuum leak
    Base timing
    Would be my two go to’s at this point
    Hook up a vacuum gauge and see what it says
    What’s your fuel pressure at? Mechanical or electric fuel pump?
  7. Steve Duleck
    Steve Duleck
    Thanks gents.
    Yeah flex plate, mech fuel pump. not sure of the pressure but the pump came from a 350 and ran great.
    I have a vac gauge and its about 17 and fluctuates. acting like a valve not seating. Timing at about 10*
    She idles good before.
    Thanks again
    Steve
  8. Steve Duleck
    Steve Duleck
    Hi,
    Run through the valve again, zero lash and a 1/8 turn, seems like number 8 exhaust was keeping the valve open at 3/4 turn. The Chinese lifters (second set) are really shet. I have a set in the 350 and it took awhile to bed in.
    anywho the motor runs good now, no shutting off after a good rev.
    Thanks all for the help.
    Cheers
    Steve
  9. lothiandon1940
    lothiandon1940
    Thanks for getting back to us with the good news.
    lothianwilly71 likes this.
