Newbie Cheater Slick Size Question
Discussion in 'The Hokey Ass Message Board' started by 29Coupe, Apr 13, 2006.
  1. 29Coupe
    29Coupe
    Want to pick up some cheater slicks for my full-fendered 29 Coupe.
    The tire sizes are a little confusing to me. I'm sure my fellow hamb-ers can help me out.
    Radir's: Listed as 8.20-15. Is the "8.20" the tread-width in inches? What about tire diameter.
    Stockton Wheel: Listed as 27X9.5R-15. Is the "27" the tire diameter? What is the 9.5R?
    Also, what about the "cross section". Is this refering to the overall width of the tire? Wall to Wall?
    I'm open to size recommendations too.
    Thanks for the help!
    -Jeremy
  2. Thirdyfivepickup
    Thirdyfivepickup
    Yes, tread is 8.2" those are 29" tall. They have specs a little further down on the page.
    Yep, 27" diameter on those... the 9.5 should be the cross section width, which is the true width of the tire at the widest point on the sidewall while mounted on the suggested rim size.
  3. 29Coupe
    29Coupe
    Thanks!
    -Jeremy
  4. 29Coupe
    29Coupe
    Anyone running cheater slicks on the back of their full-fendered Model A's?
    Looking for recommended sizes.
    Thanks!
  5. HOTRODRUBBER
    HOTRODRUBBER
    Howdy!!! Adams Hot Rod Rubber Here!!!!!!
    We have recently started building 28 3/4"x7 1/2"x15"
    WHITE WALL RADIALS. Have had alot of customers happy with size on full fender early rod's. Also 27 1/2"x7"x15" also in white wall.
  6. 29Coupe
    29Coupe
    Hey HOTRODRUBBER,
    Do you have a website? Prices on those radials?
  7. HOTRODRUBBER
    HOTRODRUBBER
    Yo!!!!!!!!!
    28 3/4"x7 1/2"x15" w/w $380.00 pair
    27 1/2"x7"x15" w/w $380.00 pair
    These tires are capped on brand new radial casing
    NO CHARGE ON GROOVING ON THESE TIRES!!!!!!!
    WWW.HURSTRACINGTIRES.COM
    H.A.M.B. DISCOUNT 10% OFF
  8. hlhpa
    hlhpa
    Do you have a hard rubber compound on slicks ? I 'am building 60's type dragster and want the smoke without the traction?
    thanks Howard
  9. repoman
    repoman
    You can't expect a recapped radial to hook up any better than the slicks of the old days, even if they glue the softest compound on them.
  10. Trust me, with Hursts, you WILL spin them on a digger. My T lights em up at will. Ryans 38 is downright nasty churnin them things.
