Hi there, my name is Patrick and I live in Perth, Western Australia. I'm 26, nearly 27 years old and after tinkering with the idea; (also having a so cal front end, currie 9" rear end, stock 1929 5 window coupe and a big turbo helped), I decided it's now time to build my very first hot rod. Without going into too much detail it's a 1929 Model A 5 window coupe, building my first ch***is, 100x50x4mm RHS stretched 5", 6" front kick, 13" rear, about to start a 5" roof chop, will then get channeled 4". Fixed body to ch***is so I can run a full cage, bracing through the firewall and a X infront of the motor to stop it from twisting... All this will be thanks to a 460ci BBF and a Borg Warner SX400-75 turbo. Enough said here's where I'm up to at the moment...
Well as it was my fathers 56th bday today I decided perfect time to take out that unwanted height in the roof... Tomorrow the realigning and welding begins!
