hello all, after browsing this site for the past month i decided to join. i am building a rat rod out of a 1939 buick business coupe using a 48 buick ****** motor and rear end. hopefully completing it by spring
If you have been browsing the site for a month, you should know you DON'T use the "R" word. Welcome and enjoy.
well i guess it could be also called a hot rod as the ch***is and all body work will be done straight and true im just running it in black primer... its not a rust bucket by anymeans
learning fast huh! beware of the "r" word. Welcome from the jayhawk state. iam just using black until they make something darker.
Once again semantics comes into play. It's easy for you young guys to fall into the trap of calling something a R..R.. simply because it's in primer. That's not always the case. It sounds like you know that you are building a Hot Rod so full speed ahead and good luck. It's in***bent upon us here to educate as well as sometimes "scold" the next generation. Oh and by the way, you guys really need to start using caps in your texts and emails. It's the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse. Welcome.
