Technical Newport Eng. Wipers
Discussion in 'The Hokey Ass Message Board' started by TagMan, Mar 13, 2017.
  1. TagMan
    TagMan
    I'm planning to go with the Newport Engineering dual wiper set-up in my '36 Ford, mostly due to the feedback posted here & on Ford Barn. A little pricey, but I like to tour, so it'll be worth the money, I hope.
    A question I have - does the motor protrude out of the header panel or does it look like a stock set-up when installed, with just the off/on and adjustment rods showing? Anybody have a pic of it installed?
    Thanks,
    -Bob
  2. nickleone
    nickleone
    Google is your friend. Go to:
    https://www.fordbarn.com/forum/showthread.php?t=148226
    Nick
  3. atch
    atch
    Suggest you call New Port directly and ask. Those folks are super knowledgeable about what they sell.
    (636) 239-1698
    39cdan likes this.
  4. chaos10meter
    chaos10meter
    from PA.
    Put a set on my 49 Merc. and everything was under the dash
    I'm very happy with them
    39cdan likes this.
  5. blackanblue
    blackanblue
    I installed a unit in my 52 GMC to replace the vaccum wipers, worked perfect with the original rods and clips just a bolt in, very high quality imo.
    39cdan likes this.
  6. Chuck Craig
    Chuck Craig
    from Ocala FL
    Have been using one of their units on my 39 1/2 Ton Chevy for over 5 years and 60k miles with no issues, I also bought the intermittent switch (worth the cost) if you plan on driving it when the weather is ??????
    39cdan likes this.
  7. cshades
    cshades
    from wi
    I installed the kit in 2 different 35 ford coupes. It fits behind the header without modification. It is a bit of a fight to get in place but it looks and works great once it is done.
    39cdan likes this.
  8. bobss396
    bobss396
    Got one on my '59 and a little bigger than the stock Trico that was on it.
    39cdan likes this.
  9. 39cdan
    39cdan
    Talk to Bob at Newport. This has 200k miles on it with Newport Engineering wiper.
    I will admit it was the best and easy upgrade ever. Bolted right in. IMG_0552.JPG
