newport engineering wiper conversion kit
Discussion in 'The Hokey Ass Message Board' started by nunattax, Jun 12, 2012.
  1. nunattax
    nunattax
    has anyone used their stuff whats the quality like.thinking of fitting to my 38 chevy pu
  2. honeyman
    honeyman
    from Steiner
    Quality is OUTSTANDING as long as it really fits your application. With your Chevy PU, probably no problem. I'd call 'em and grill 'em before I ordered. With my '50 Plymouth, it wasn't even close to something I could make work. There are "issues" with '50, '51 Plymouths as to vacuum vs electric originals. Other than fit, I was VERY impressed with their product. ****s being a MoPar guy...
  3. Boones
    Boones
    from Kent, Wa
    quality is good, had them on two cars, my only issue is the 90 degree max swing. I would not use them again if I needed more than that (most cars do). I would use a cable driven set up next time
  4. buckd
    buckd
    I've put them in several cars and all just bolted right up and have worked great in my own rides for years. It's worth it to upgrade to the variable+ 2 speed switch. I don't think anyone else is making them. If there is; someone chime in!! BUCKD
  5. I have a 48 Chrysler with a 6volt wiper motor...will anything interchange with it or do I have to get creative ?...My guess is that it wouldn't last very long on 12volts before it goes up in smoke !
  6. 48 Poncho
    48 Poncho
    from Tennessee
    Bolted right up to my 48 Poncho and have worked great so far.
    48 Poncho
  7. gnichols
    gnichols
    from Tampa, FL
    Best stuff on the market. Gary
  8. I have had one in my 55 Safari for a number of years and the installation was easy.Hardest part was running the wire thru the firewall.The only complaint I had was the set screw for the knob was in a position that would not allow it to be mounted with the lettering reading level due to the proximity to the roll of the dash panel.I notified them about it but don't know if they ever modified them.
    If I were to buy another(which I probably will for my 57 Safari)I would definitely upgrade to the 2 speeds.
  9. squirrel
    I have an old one (1996) in my 55, it works ok. The switch is kind of flaky, and it took some work to get the stock knob on it. I have a couple more for my project trucks, but haven't got them in yet.
    It's a big improvement over a vacuum wiper system.
  10. butcherted
    butcherted
    from hagerstown
    I have had one in my 50 Chevy for about 8 years, works great easy hook up.
  11. hotrodgypsy
    hotrodgypsy
    from reading,pa
    i have their system in my 48 chevy sedan delivery...good quality..wish i would of gotten the delay wiper switch....
  12. tb33anda3rd
    tb33anda3rd
    i have one in my '39 gmc, it works ok, broke the little aluminum connector when the blades froze up, and when driving over 55mph the blades blow up off the windshield, i think cable is worn but after being used as a daily driver year round in new england a little wear after 20 years is to be expected.
  13. d2_willys
    d2_willys
    from Kansas
    Looks to be quality, but awfully costly, especially when adapting to 6v systems. The up converter (to 12v for motor) is another expensive piece. And then you have to send them your vacuum motor for adapting your drive tang to their motor. The 2 speeds and variable speed units sound like the way to go.
    I myself am going a different direction and using a motor from a Jeep or motor from mini van back window. Then do the up converter myself. Some simple sheet metal bracketry and presto! I have at least 6 vehicles with vacuum wipers, so if I were to go Newport way, it would be way too expensive.
  14. Flatheadguy
    Flatheadguy
    Got a kit for my 39 Ford, high mount at top of windshield. It fit exactly as it should. Instructions were right on the money. And, best of all, it works great. Will buy another for my next project.
  15. just put one in my girlfriends 50 pontiac AWESOME thinking of putiing one in my other old cars now
  16. nunattax
    nunattax
    thanx for the replies,all good.this kit is new to the market 37 /38 pu i am going to go for one with the optional delay switch. CHRIS
  17. Belchfire8
    Belchfire8
    I put one of their motors in my '46 chevy and it worked great. I tried to adjust the switch, which didn't need it, and I screwed it up. I called them for advise and they said to send it back to them for repairs. It was back to me within a week and there was no charge to fix my screwup. I reccomend them to anyone looking for electric wipers.
    nunattax likes this.
  18. okiedokie
    okiedokie
    from Ok
    Got em in all three of mine. Work and fit excellent. Been in my 46 coupe for probably 12 years.
  19. Acme Speed Shop
    Acme Speed Shop
    MODERATOR
    from so cal
    I have installed them in quite a few of my cars and trucks; never an issue and always worked well. Strong, silent motors and good self-parking feature.
  20. Weedburner 40
    Weedburner 40
    That is a smart move. I have installed several, have one in my Delivery and about to install one in a 40 Panel. Excellent product and the Galbreaths are great people.
  21. 41plym
    41plym
    I put them on my 41 plymouth coupe. High quality product that works great.
    Here in the wet northwest good wipers are a must have.
    41plym
  22. fordcragar
    fordcragar
    from Yakima WA.
    I put one on my 47 Chev over twenty years ago and have had no problems with it.
  23. tb33anda3rd
    tb33anda3rd
    the delay is a good idea, and works well.
  24. bangngears
    bangngears
    from ofallon mo
    I put one on my 40 Ford coupe and the first time i used it was in an early spring blizzard.A stock vacuum wiper would never have gotten me thru it.
  25. chaos10meter
    chaos10meter
    from PA.
    Great stuff. I always said it's the only thing I bought for the sled that fit.
  26. olcurmdgeon
    olcurmdgeon
    Just put one in my '50 Ford this week. Works great, quiet. Did have an install issue, turns out my fault, but a quick call to them and they emailed two photos that solved my problem (had the underdash wiper arms mixed up). Only thing I see that would make it better would be for them to tack one of the two attachment nuts to the plate the motor is on. My old fingers just couldn't get the nut up there and get it started with just enough clearance to get the nut itself in position. But a dab of epoxy held the nut so I could get the machine screw started. Been raining so much here in east I was tired of the vacuum setup!
  27. CB_Chief
    CB_Chief
    from Oklahoma
    If you want to have some leeway in mounting and still have a nice workable system go looking in your local salvage yards for an MGB. Rob the entire system including the transmissions than you can adapt it to your truck. The MG system is cable drive and the motor mounts under the dash on the p***enger side. IT's a really straight forward system and reliable too. The MGB/C/GT series was made in a roadster and a hatchback hardtop (MGB-GT) from 1962 to 1980. Be sure to take the bracket also.
  28. fordcragar
    fordcragar
    from Yakima WA.
    There are some nice units that can be adapted, if that is the way you want to go. One thing about the Newport Engineering kit, is that it fits right out of the box.
  29. 41 C28
    41 C28
    I run the 6 volt 2 speed wipers in 48 Dodge on 12 volts, although sparingly. Slow speed is fast and fast speed is real fast. I also keep the Rain-X handy.
  30. R A Wrench
    R A Wrench
    from Denver, Co
    Installed a unit into my F1 pickup. Not too difficult to get hooked up, needed to modify the defrost vent on the drivers side. Has the 2 spd switch with park setting, everything has worked great.
