newport engineering wiper conversion kit
Discussion in 'The Hokey Ass Message Board' started by nunattax, Jun 12, 2012.
  1. Old F.A.R.T.
    Old F.A.R.T.
    Used one of their kits in my 1962 Impala as a replacement motor was hard to get...works GREAT...Very happy with it
  2. Sorry about pullin this one out of the archives, but I just have to say that I am delighted with the Newport wiper motor that I just installed in my 55 century. Perfect bolt up. Had the whole caboodle working in no time. Pricey critter, but workmanship is highest quality and cannot fault.
  3. falconsprint63
    falconsprint63
    from Mayberry
    they have a delay switch now--man I've had mine a long time :D
  4. OLDSMAN
    OLDSMAN
    When I built my 48 Olds conv, I lnstalled their kit with delay and washers as the Olds had factory washers. It fit in where the vacuum motor bolted on, had no problems, and the motor wotor works flawlessly. As someone else said the Gailbreths are both super people. I would recommend their kit to anyone
  5. nunattax
    nunattax
    Well i ordered a wiper kit for the 38 tonite,with intermittent switch.my buddys got the kit in his 52 chevy pu as well.nice people to deal with
  6. junkyardjeff
    junkyardjeff
    Last year I put a kit in my 55 ford and very happy with it even though I only used it a few times since installing.
  7. fordflambe
    fordflambe
    Been running one in 41 Ford Sedan Delivery for 15 years........has intermittent control and washers.........very quiet (practically zero noise) and works great!
  8. 35chevymaster
    35chevymaster
    from indiana
    ditto have used 3 no probs.
  9. James Curl
    James Curl
    I have one in my 55 Chevy pick up, only problem happens when you try to run them on high speed above 70 mph. They come around the curve in the windshield and the load to being them back blows the fuse. On my 48 Plymouth I have a problem with them not parking but continuing to run after turning them off. contacted the manufacture and adjusted as suggested, worked long enough to get the car inspected and a new sticker. I now just reach under the dash and pull and replace the power wire to the switch to activate them. I will probably buy another kit from them to replace the one in my 48.
  10. turdytoo
    turdytoo
    Have been involved with 3 and wouldn't consider anything else. All original steel bodied cars- '26 &'28 sedans plus '32 3w.
