History NHRA Junior Stock
Discussion in 'Traditional Hot Rods' started by colesy, Aug 12, 2007.
  1. KickinAsphalt
    KickinAsphalt
    from Pa
    I am simply trying to get educated a tad.
  2. CTAV8
    CTAV8
    Is it just me or does this thread keep getting better every day?
    So much knowledge here. I really appreciate all the effort to keep it rollin'.
  3. Jimbo17
    Jimbo17
    CTAV8:
    I used to have a store in Cos Cob over by the old diner on the Post Road. Valley Road still look about the same has it was 25 years ago?
    Jimbo
  4. tommyd
    tommyd
    from South Indy
  5. 56 Pontiac I/SA
    56 Pontiac I/SA
    from Maryland
    Great images (many unseen before on this thread) posted lately. But it would be nice to see (in addition) a bit of 'dialog' going.
    A few years back, I started a narrative called 'Lo-Buck Tricks.' Lots of new members/viewers since then -- perhaps it's a good time to re-visit that topic.
    Also, it would be interesting to discuss the very-best *'legal' (*for a while) Lo-buck trick of them all -- the (intentional) VACUUM leak.
    Spot the 'Lo-Buck' tricks. (more than five).
    hendelec likes this.
  6. 56sedandelivery
    56sedandelivery
    Smaller battery, cool can, air cleaner "lid" only, quick remove valve cover hold downs, no heated choke, larger pulley on generator, additional breathers, headers, plug wires separated to reduce crossfire, and the fan belt looks to be a little "loose". I am Butch/56sedandelivery.
  7. tommyd
    tommyd
    from South Indy
    Well, the cool can , the super loose generator belt , the cut -up air cleaner base to keep hot air out of the carb , gonna ***ume that the carb mounting bolts are loose on purpose to pull more air , and...........the wooden disc on the carb?
  8. tommyd
    tommyd
    from South Indy
  9. tommyd
    tommyd
    from South Indy
  10. tommyd
    tommyd
    from South Indy
  11. tommyd
    tommyd
    from South Indy
  12. tommyd
    tommyd
    from South Indy
  13. tommyd
    tommyd
    from South Indy
  14. tommyd
    tommyd
    from South Indy
    10321169_705625812843896_6873854847046253119_o.jpg Repost?
  15. tommyd
    tommyd
    from South Indy
  16. tommyd
    tommyd
    from South Indy
  17. tommyd
    tommyd
    from South Indy
  18. tommyd
    tommyd
    from South Indy
  19. tommyd
    tommyd
    from South Indy
  20. tommyd
    tommyd
    from South Indy
  21. tommyd
    tommyd
    from South Indy
  22. Lyn Smith
    Lyn Smith
    The vacuumn leak trick was used mostly on the lower cl*** 2 bl cars.they used 2 carb gaskets,a loose carb,or one with spings on top of the carb studs that would tilt the carb,and cause a air leak when the throttle was full open.
  23. 56 Pontiac I/SA
    56 Pontiac I/SA
    from Maryland
    Well Butch, Tommy, and Lyn -- you are all 'spot on.' The reason the HEADERS were "Lo-Buck" is because I made them from J.C. Whitney's ($39.00) "U bend" (flanges, gaskets, and U-shaped tubing) you-build 'header kit'. As far as the (admittedly 'tacky') cover on the carb goes, it was just a way to keep dust out (when parked of course) at dirt-pit tracks like Monrovia, Maryland's 75-80 "Drag-O-Way.
  24. tommyd
    tommyd
    from South Indy
  25. 56 Pontiac I/SA
    56 Pontiac I/SA
    from Maryland
    By the way, who knows the REAL reason 'cool cans' were used. It had nothing to do with 'chilled' fuel going to the carb!
  26. tommyd
    tommyd
    from South Indy
  27. tommyd
    tommyd
    from South Indy
  28. tommyd
    tommyd
    from South Indy
    10612670_10204465292905698_4034231049507832738_n.jpg Bock "Drag Star" trailer. Top shelf hauler back then.
  29. tommyd
    tommyd
    from South Indy
  30. tommyd
    tommyd
    from South Indy
