nhra tech question
Discussion in 'The Hokey Ass Message Board' started by El Loco Worm, May 21, 2008.
  1. El Loco Worm
    El Loco Worm
    from oklahoma
    I can't find my rule book and was needing to know what the tubing requirments are for a cage in a car running 10's? I have to order my tubing tomorow so I can do stuff this weekend. Plus it gives us another excuse to use our tubing bender, nice smooth mandrel bends sure are pretty!
  2. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
  3. Roothawg
    Roothawg
    .120" mild steel .095 chrome moly That is from memory, so check it out before ordering.
  4. OLDSKEWL61
    OLDSKEWL61
    yea i think it was 1.75in min .120 dom cromolly
  5. Al Napier
    Al Napier
    from Central CT
    For door cars the min tubing thickness is .118 mild steel I believe, BUT, purchase the heavier (.135 or something like that) as much of the .118/.120 comes out too thin to pass spec.
    I'll double check tomorrow (my SFI doorcar book is at the office) but I think for 'moly it's .083 min.
    Al in CT
  6. dragrcr50
    dragrcr50
    buy the dom 1 3/4 .134 wall if you are doing a 6 or 8 point, if you are doing a cage ie, 10 or 12 point then you can use 1 5/8 dom .134 wall so it will sonic test to .118 in the bends. and you only need all of this to certify the chassis if you are going to run 9.99 or quicker . if not it is recomended basically . you have to have a roll bar at 11.90 i think and a cage at 10.99 along with other factors like firewall floor etc being changed. but what i am saying is if you dont certify as long as it is the right diamater it will pass tech. but remember your life could be at risk....
  7. El Loco Worm
    El Loco Worm
    from oklahoma
    Thanks for all the replies. I don't plan on the car being any quicker than high 10s but I want the car to certify to 9.99. I want my ole turd to be as safe as possible no shortcuts anywere! We have the technolgy to go fast and be safe so I plan on using it!
    Thanks again,
    Worm
