Nice to be here, and a Mercury flathead OD tranny question
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by mdogg1950, Mar 19, 2025.
  1. mdogg1950
    mdogg1950
    I think this site with its like-minded people are just what I've been looking for! I've always wanted a '49-'51 Mercury and finally at the tender age of 72 I acquired one. Nice, solid body but it was an interrupted project as the owner had p***ed. Lots of work to do, but I'm up for the challenge.
    Regarding the OD ******, there is a shifter fork on the OD that appears to have two positions. Is the forward position OD disengaged? I don't plan on hooking up OD right away, just want to get "Rebel50" on the road.
    Thanks in advance,
    Matt
    Toms Dogs likes this.
  2. pprather
    pprather
    Welcome to the HAMB from Illinois.
    I can't remember who the O/D experts are, but there are several threads on this subject.
    Maybe @squirrel can answer your question?
    Slopok likes this.
  3. Slopok
    Slopok
    Let's ask Anthony, he will have the answer. Stay tuned. @anthony myrick
    pprather likes this.
  4. Slopok
    Slopok
    You most definitely want to get it operable, makes a huge difference in the drivability of a flathead powered or any other engine powered vehicle for that matter.
    squirrel likes this.
  5. Pushing the cable on the dash in allows OD to be engaged? I’m building one now. Been a while since using one.
    Lever on the trans pointing towards the rear should engage it on mine that’s a 49-50 unit
    Foward should disengage
    If my brain isnt backwards.
    If you put the 1st/reverse lever in reverse, it disengages OD
    That will verify the direction needed
    The OD shift fork in the OD unit moves towards the rear to disengage the OD
    If the soliniod isn’t stuck, power off to the solenoid disengages the OD pawl in the OD unit.
  6. Internal view of what’s going on
  7. squirrel
    If you don't want the OD to function, keep it "locked out", cable pushed in all the way.
    But when you get around to it, see if you can get it working as designed, and read the manual about how it's intended to be used. Probably not like you thought.
    anthony myrick likes this.
  8. This is a 49-early 51 OD
    Goes back when shifted out of reverse
    alanp561 likes this.
  9. mdogg1950
    mdogg1950
    Thanks everyone for your replies! Pics and diagrams are a huge help. I'm in uncharted waters but loving every bit of the journey. I'm sure I'll have more Merc questions to come. And since I've owned a '49 Chev since 1997, I'll be glad to share my little bit of expertise with any Bow-tie lovers out there.
    Matt
    (Waterloo, Iowa)
  10. alanp561
    alanp561
    Welcome from East Tennessee. We really like pictures.
  11. Make sure you have a working parking brake
    Slopok and alanp561 like this.
