Hot Rods nine inch ford question
Discussion in 'The Hokey Ass Message Board' started by Ghost28, Mar 29, 2021.
  1. Ghost28
    Ghost28
    how do you loosen the clutch pack on a completed 9 inch ford pumpkin to make adjustments to the clutch pack splines?
  2. 57 HEAP
    57 HEAP
    Are you saying the splines don't line up and the axle shaft won't go all the way in?
    Try twisting the axle shaft until the inside splines do line up.
  3. Ghost28
    Ghost28
    exactly. I have put both axles in and tried twisting, no joy at this point. This is a new setup and I am sure the clutches are really tight
  4. squirrel
    the other way to do it is to take it all apart and put an axle in the splines when you put it back together.
  5. jaracer
    jaracer
    I had the same problem, but I was able to twist the axle enough to get them to line up. If I remember right, I had a pretty long bar across the lugs to get it to twist.
    Also, did you use the gauge to set the clutch pack clearance? It may be too tight.
    Ghost28, seb fontana and squirrel like this.
  6. Ghost28
    Ghost28
    Yeah Jim. I kinda wished they would have done it right in the first place.
  7. Kevin Ardinger
    Kevin Ardinger
    If I remember correctly, one axle should go in as it only has the side gear to line up. Hold that one with a big bar and turn the other with a big bar.
  8. deathrowdave
    deathrowdave
    from NKy
    You are in for a fight , like Jim said , really easy if done correctly . Tough the way your trying to do it
  9. Ghost28
    Ghost28
    Thanks guys. I locked down the pinion to a heavy engine stand, and put in the long axle p***enger side, then with the big bar I was able to turn that axle just a bit. Then by the grace of GOD It finally went together. YAHOOO
    stillrunners, saltflats and squirrel like this.
  10. mgtstumpy
    mgtstumpy
  11. Wanderlust
    Wanderlust
    Been there done that, not a lot of fun, glad it worked out for you.
    stillrunners likes this.
