Projects No Fuzzy Dice...Digging the History of my '57 Chevy Convertible Drag Racer
Discussion in 'Traditional Hot Rods' started by flamed34, May 19, 2022.
  1. flamed34
    flamed34
    Thanks.
    VIN and data plate don't call out manual or auto in 57, but all the linkage, z bar, etc look factory. The engine suffix in the car was auto, but build date of the engine doesn't correspond to build date of the car so i know it was changed. Also, there's evidence there was once a hydrovac unit...only used with manual cars for power brakes.
    I'd love to let engine masters build it up, lol
  2. Shain
    Shain
    from Omaha
    As was probably described previously.....
    57's only had 3 speeds and automatics from the factory. Never made 4 speeds in a 57 full bodied cars...only Corvettes.
    No floor shifters (3 speed or automatic) from the factory in 55-57 cars. ALL were on the column.
    Corvettes had a 4 speed floor shifter
    Back in the day it was pretty common ,,,,just about everybody converted automatics to 3 speeds, and in mid/later 60s it was the T-10 or Muncie 4 speed. You could dealer buy the clutch pedal, and everything to make the conversion. A new Muncie 4 speed was about $200 to $250
    One of the pixs show the engins, Corvette valve covers with wing nut chrome hold down "bolts". We used the same thing on our race cars in the 60's. (quick valve cover removal)
    Those ported and polished heads are beautiful. Crane and Mondello made the some of best out there in the 60s. Fairly rare even back then.
    (would guess the valve stem seals are hardened and will need to replace....another item for the list of to do's :))
    What a rare catch of vintage stuff...wow
  3. rockable
    rockable
    Wow! Great score!
    flamed34 likes this.
  4. flamed34
    flamed34
    Thanks!
    It appears that early on it had a 3-speed floor shift conversion. I'm convinced the car came as a manual based not just on the linkage but also that it has the holes and evidence a hydrovac was mounted at one time. I've looked at a lot of restored automatic pictures and don't see the hydrovac holes present (not that it's definitive, but seems to be a good indicator). Later it looks like the 3 speed shifter hole was blocked off and it got the T10 4 speed which appears to be a 1962 Corvette unit based on castings and aluminum case (I have a T10 in my '60 Impala 348/4 speed which is the cast iron case used in p***enger cars). 1962 is also the year that he bought the heads/cam so he was clearly on a mission to go faster!
    VANDENPLAS, Deuces, Toms Dogs and 5 others like this.
  5. Toms Dogs
    Toms Dogs
    from NJ
    I noticed one of your cardboard boxes were marked 'Dons Speed Shop'.
    * Don Raleigh resides in Stockton , NJ and is a H.A.M.B. and Ford Barn member. ( 5 quart ) :D
    Budget36, Torkwrench, Deuces and 4 others like this.
  6. flamed34
    flamed34
    Seriously? Holy shiite!
    chryslerfan55, Deuces and razoo lew like this.
  7. Toms Dogs
    Toms Dogs
    from NJ
  8. 6sally6
    6sally6
    OH MY GOODNESS....what a find!
    6sally6
    VANDENPLAS, Deuces and flamed34 like this.
  9. You have a time capsule of great items most of us have never seen before. Not to mention a killer 57 convertible. Congratulations on your purchase.
    chryslerfan55, Deuces and flamed34 like this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
  11. NoSurf
    NoSurf
    Very cool.
    chryslerfan55 and flamed34 like this.
  12. 325w
    325w
    My vote is the car was a power-glide. Picture in post 56 looks like an automatic column that has been modified. Shows the nut sert to mount selector detent bracket.
  13. 427 sleeper
    427 sleeper
    3 speed manual's had the same column's. 3 spot weld's on the cross shaft bracket's to the frame for factory install, which he has. The car is Legit...
    SS327, Deuces and flamed34 like this.
  14. Toms Dogs
    Toms Dogs
    from NJ
    Here's a 10 1/2 min. video taken at York Pa US 30 Drag Strip... briefly showing a '57 Chevy "Puffy" ragtop within the first several minutes___
    *I was at this location ( York US 30 Drag Strip) but several years later, with a couple U.S.A.F. pals, around '1963 -' 64.
  15. guthriesmith
    guthriesmith
    What are the chances that black convertible was this car?
  16. flamed34
    flamed34
    Awesome vid!
  17. flamed34
    flamed34
    The car left the factory Incan Silver. I may discover in the layers there was a color change in between but not likely. How I wish that car was silver
  18. guthriesmith
    guthriesmith
    Got it. Yea, I was shocked when they paused on the driver in that specific car. That would have been too cool if it was yours.
  19. TomT
    TomT
    What a fantastic find - you have won, hands down the hot rod lottery of all lotteries! Just unreal! Good luck with it and I hope to see it together, running and driving some day …. You don’t live all that far from me !
  20. flamed34
    flamed34
    A little teaser...
    I picked up the Model A rumbleseat roadster I bought as part of the deal today. The widow gave me folders of do***entation, correspondence with Norman Latham on the supercharger, price lists, repair invoice, installation instructions, a Latham fold out brochure, and information back on application on a 327 he was building (***uming that's where the heads were going)...
    Can now see why no one has seen the cast badges...they were a separate $3.00 (see the card).
    I guess the decals are even more rare.
    Plus lots of do***entation on the other parts.
    It'll take a while to get good pics of everything but here's a little for now 20220529_214449.jpg 20220529_214457.jpg 20220529_214519.jpg 20220529_214529.jpg 20220529_214613.jpg 20220529_214620.jpg 20220529_215018.jpg 20220529_215024.jpg 20220529_215029.jpg
  21. i7083
    i7083
    Damn...
  22. chevy57dude
    chevy57dude
    Thank you for not restoring the car to stock!
    Man, that stash is a one of a kind jackpot. All the exact right parts to build the car as it would have been done ''in the days''. Duplicating this would be difficult. Glad it fell into proper hands. Someone with less insight would have sold off the speed equipment.
  23. 427 sleeper
    427 sleeper
    You've definately unlocked the vault!!! Will the coolness ever end??? I hope not!!! :cool::cool::cool:
    flamed34, Shain and chevy57dude like this.
  24. Pav8427
    Pav8427
    That is one awesome collection of schtuff.
    I love the plan.
    With all the goodies, all you need is 2 more bodies and it could be a AMT 3 in 1 kit.
    Stock, Drag or Custom.
  25. 57 Fargo
    57 Fargo
    I’m going to repeat what I said before:
    Jesus….
    You sir have hit the coolness jackpot.
  26. 55Belairretrorod
    55Belairretrorod
    from Australia
    Did you get any info on the racing history of the car?
  27. flamed34
    flamed34
    Not yet, other than what family told me. I know he raced at Old Bridge in Englishtown and probably some of the other NJ tracks. He also made several trips to Watkins Glen but it's unknown if he raced or was just a spectator.
    The family is still going through his files. He saved everything so hopefully there's some racing slips or photos
  28. panhead_pete
    panhead_pete
    Outstanding find and approach to preserving the intent of this car. Kudos, especially not low balling the family! Looking forward to watching this progress. Thanks for sharing.
  29. Atwater Mike
    Atwater Mike
    Really liked the sharing of pix of treasure!
    I bought a '32 three window mid-project from a friend's Mom, lots of parts came with it. I also insisted she take a fair price, (she had 'lowball offers' that would piss off a preacher)
    But nothing near this!!! Thanks.
  30. flamed34
    flamed34
    A little bit more of the Latham info...more to come... 20220601_193524 - Copy.jpg 20220601_193530 - Copy.jpg 20220601_193544 - Copy.jpg 20220601_193553 - Copy.jpg 20220601_193626 - Copy.jpg 20220601_193640 - Copy.jpg 20220601_193653 - Copy.jpg 20220601_193701 - Copy.jpg 20220601_193713 - Copy.jpg 20220601_193715 - Copy.jpg 20220601_193759 - Copy.jpg 20220601_193806 - Copy.jpg 20220601_193843 - Copy.jpg 20220601_193854 - Copy.jpg 20220601_193924 - Copy.jpg 20220601_193930 - Copy.jpg 20220601_193935 - Copy.jpg 20220601_193941 - Copy.jpg 20220601_193950.jpg 20220601_194004 - Copy.jpg
