Hot Rods No headlight bar!
Discussion in 'The Hokey Ass Message Board' started by jtbarnet, Jan 21, 2018.
  1. jtbarnet
    jtbarnet
    Well, have not seen many 32 full fendered coupe without a head light bar!!! But get ready, I am putting fenders on my coupe, and did not think the lights were going to be low enough even on a dropped bar, so, going to drop them quite a bit lower and not use a head light bar. Will follow with pictures and what all I am going to do to fender braces.[​IMG]
    catdad49 and harpo1313 like this.
  2. BJR
    BJR
    Waiting for this, could be very cool.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Guy in our club built a street rod 3 window and didn't use a headlight bar,too me it looks strange. HRP
  4. lothiandon1940
    lothiandon1940
    I agree with you Danny.
  5. lothiandon1940
    lothiandon1940
    Headlight placement can get pretty critical. Too low looks weird, too high looks awkward, too close together looks "bug-eyed". Too far forward or too far back all have to be considered. Sometimes it takes a bit of mock-up and honest critique from fellow hot-rodders. Good luck, jtbarnet, hope you can make it work.:)
  6. rusty rocket
    rusty rocket
    I think they look just right on a dropped bar even with stock lights.
    Its your car and thats the beauty of hot rodding, You get to do anything you damn well please. IMG_0584.JPG
  7. Just Gary
    Just Gary
    I agree it looks strange, but mostly because the headlights are soooo far apart and not so much due to the lack of headlight bar.
    Just a thought.
    HOTRODPRIMER and lothiandon1940 like this.
  8. linechaser32
    linechaser32
    from Iowa
    What I have been doing is I narrow the headlight bar then drop it and use the bottom stock bar hole in the fender as the top hole. This makes the lights lower,and closer together.i don’t like the looks of a 32 without a headlight bar either.
    lothiandon1940 likes this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Henry Ford should have used a dropped headlight bar. HRP
  10. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Plus the fact that they're not on "chopped" headlight stands, so the small headlights are floating up above the fender surface giving them a "snail eye" dune buggy look.
    This happens on 33/34 Fords. That's why most guys go with chopped stands to tuck them down.
    Also, they're very far forward on that 32. Without the accompanying bar running across the front of the grille, the lights don't need to be hanging out front and could/should be slid back a bit next to the grille shell.
    lothiandon1940 and Just Gary like this.
  11. Danny I think on a fender car if no light bar is used the headlights need to be right down where your fog lights are. If course I like my lights low so maybe that is why I think that.
  12. Hnstray
    Hnstray
    from Quincy, IL
    The headlight bar serves another purpose besides mounting the headlights. It ties the fender braces together and adds strength to the combined ***embly, minimizing 'fender flop' of vertical vibration. The OP does say he is going to do something with the fender braces, so sounds like he has thought this through.
    Ray
  13. HOTRODPRIMER
    HOTRODPRIMER
    Ray,you got that right,the purple 3 window followed me one night and the light was shaking around a lot. HRP
  14. Mr48chev
    I've always thought that the dropped bar like on the blue one that Rusty Rocket posted in post 6 just flat looked right for a hot rod with fenders on it.
  15. 56don
    56don
    There was a local guy here a couple of years ago that was running a full fendered 34 Ford pickup truck with no headlight bar. Each light was attached to the fender/fender brace with what looked like a headlight stand off of a large truck like a White or something. The lights were in the exact same position as stock but with no bar across the radiator shell. It looked good and you would hardly notice the difference just walking past it.
  16. jtbarnet
    jtbarnet
    I really, really appreciate all the input guys, as far as braces, I have thought that part thru, I am going to build “gussets” down each side of fender braces, and also put small tab on back on brace, TIG weld everything, and off of the gusset tab bolt to top of shock bracket. I am build brackets for headlights and bolt to inside of frame, they will be a little lower, but centered between fender and front grill.....just lower than on a dropped bar. So my finders will be supported real strong and will not move, and the headlights will be supported strong and will not flop. One thing guys beside saying I will the head lights a little lower than on a dropped headlight bar, I fail to also let y’all know I have a 2” longer hood, so I would have to highly modify the bar to come out 2” ( at least) and drop more.....anyway, will be sure and post pictures, if you guys would like I will also post picture of the modifications I make to fender support....
    Jim
    Hnstray and lothiandon1940 like this.
  17. Tjompen
    Tjompen
    14755665204_ac38a54f7e_b.jpg Here is my car without headlight bar. 160702wheels88.jpg
  18. Joe Troilo
    Joe Troilo
    Here is my 32 Cabriolet without a bar. Made tubular fender brace to serve as headlight stand and secure fender. Lights are European driving lights with halogen bulbs. Dimpled fenders to get lights lower.
    Frankie47 likes this.
