Technical No heat??
Discussion in 'The Hokey Ass Message Board' started by Rob L, Mar 10, 2024.
  1. Rob L
    Rob L
    New thermostat, flushed the heater core. I have air blowing from the floor vent but no hot air. Any ideas on what the fix might be?
    Thanks.
  2. KevKo
    KevKo
    from Motown
    Pics and more info needed
    squirrel likes this.
  3. BJR
    BJR
    What car, what kind of heater? Depending on the year of the car it could be a air door not opening, heater control valve, hoses hooked up wrong or to the wrong place, coolant blockage. So we need pictures of the heater and pictures of the engine compartment to help.
    Mr48chev, jaracer and Tow Truck Tom like this.
  4. goldmountain
    goldmountain
    You might have an air lock. Try filling the rad with a heater hose disconnected and plug it back in when the antifreeze appears.
  5. 05snopro440
    05snopro440
    Yep, seems pretty common to get an air lock.
  6. Come on, guys! We are WIZARDS!
    Ben
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Forgot to add water. :)
  8. alchemy
    alchemy
    Warm up the engine?
  9. gene-koning
    gene-koning
    Is either hose to the heater hot?
    If one is hot, and the other is cold, you either have air trapped in the line, or a plugged heater core, or a valve or heat control turned off or closed.
    If neither is hot, the coolant level is too low, or the thermostat may be defective, these days, something being new doesn't always mean the part is good.
    1971BB427 likes this.
  10. Mr48chev
    Is the heater core higher than the top of the radiator? or lower than the filler neck on the expansion tank if it is a rig with an expansion tank. That would cause an airlock if it was noticable above the other high point of the cooling system.
    As Kevko mentioned, photos of how the hoses are hooked up on the engine speak big. the outlet from the engine to the heater should go from the head or intake to the heater and the return should go back to the water pump unless you have a late model GM with a cross flow with the heater return hose going to the cold side of the radiator. = 70's chevy truck.
  11. Rob L
    Rob L
    The hoses are hooked up correctly. I flushed the system when i changed the thermostat. I think based on the replies here that there may be an air lock. I do see the coolant flowing through the radiator. Seeing the flow, could there still be an air lock? Thank you
  12. Rob L
    Rob L
  13. Rob L
    Rob L
  14. Rob L
    Rob L
  15. Rob L
    Rob L
    Yes and let it run with the radiator cap off for about 25 minutes
  16. Rob L
    Rob L
    63 buick lesabre. Hoses are hooked up correctly. I disconnected the outlet hose and flushed the core. Water was coming out freely and clear
  17. Rob L
    Rob L
    I have air coming out of the vent but only luke warm. Hoses are hooked up correctly.
  18. BJR
    BJR
    Sounds like a blend door is not moving or adjusted correctly. Unless the heater hoses going in and out are not hot. Then it’s the water valve.
    Kevin Ardinger likes this.
