Technical NO LEGROOM
Discussion in 'Traditional Hot Rods' started by Born 2 Loose, Dec 14, 2022.
  1. Born 2 Loose
    Born 2 Loose
    I have a '34 Ford pickup that was built for dwarfs. No legroom. I'm an old guy and tried bomber seats but no bueno. I'm sure others have had this problem. I've searched everywhere but most seats won't work because the rear curvature of the seat doesn't allow it to sit flat (somewhat) against the cabin wall. Of course, money is an issue. Can anybody help an old time hot rodder out with ideas? Thanks
  2. 19Eddy30
    19Eddy30
    from VA
    No easy Quick fix unless stock cab.witch adding taller seat.
    Modified to Hot Rod, cabs for short people ,5,9ish or less.
    Extend the cab
    Move the firewall , or make extension pocket for feet , moving things in that Area
    chryslerfan55 and alanp561 like this.
  3. X38
    X38
    The part you need to consider is the top of the seat. It only needs to be an inch or so thick, at least so your head isn't resting on the back of the cab or window. It can be thicker lower down in the small of your back area for lumbar support. You may have to make this if off the shelf options are not working.
    Pedals. A lot of people screw up here also. They need to fully function obviously, but be as close to the firewall as possible. Especially the go pedal. Where are yours? You should also consider the arc of travel. The s**** should move away from you as you depress. I've seen throttle s****s poking nearly ten inches out from the firewall with and almost up/down action. Plainly not good, then they drive like a crippled monkey. If necessary, kick out the lower firewall.
    Also, everything is relative. People were smaller when the pickup as made. Smaller on average than now and not fat.
    chryslerfan55, SDS, Packrat and 6 others like this.
  4. Blues4U
    Blues4U
    from So Cal
    I feel your pain, I drive a '30 Ford pickup with even less legroom. I use these seats mounted on modified seat mounts from Speedway, with the back legs cut 1" shorter than the front so the bottom cushion angles back a little: https://www.northerntool.com/shop/tools/product_8264_8264?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Farm + Acreage > Seats > Forklift Seats&utm_campaign=Wise&utm_content=1742&gclid=CjwKCAiAheacBhB8EiwAItVO2wJIsZdpSJEvBB7Xw0_W0BTRN037Bv0Mjc01HhTd1Ms_3GHArWYLrBoCWm0QAvD_BwE&gclsrc=aw.ds
    They actually work really well, pretty damn comfortable; and are probably about the best you're gonna find for leg room as well as head room (if your truck is chopped, mine is about 3 1/2"). Still, the legroom is very limited. Personally I don't mind so much, I'm good for a tankful of gas, but by then I'm ready to stop and have a rest.
    This guy has 'em in his Econoline:
  5. High test 63
    High test 63
    I have a 29A pick up and a 27T rpu. Both are clutch cars. Im 6'1"tall. There just is no leg room. Pedal placement in relation to the firewall and floor needs thorough consideration. Some room and comfort can be achieved by modifying/ adjusting pedal arm length and throw.
    In my A truck i also extended the steering column a few inches from stock which also gave me more room for working the pedals.
    I have a flat padded seat back in the A truck and bomber seats in the T. The padding is thin in the back and is reasonably comfortable but both need a lombar pad for any extensive driving.
    chryslerfan55 and bchctybob like this.
  6. High test 63
    High test 63
    I have one of these seat bottoms in my A truck, but use a padded flat plywood back. The bottom is great but the back needs some lombar support as i said in previous post.
    bchctybob likes this.
  7. Mr cheater
    Mr cheater
    On my truck witch is a 32 I used the gas tank as the seat riser and added a two inch spacer to the front of the seat riser to give the seat some tilt. I then used a 3/4 inch pice of plywood with areas cut out where your **** goes and covered that in 2 inch foam. For the back I used 3/4 inch plywood covered in half inch foam B346F484-539A-494A-B47D-658A92C959C6.jpeg 7D0D8339-EC3C-44C4-9D04-EF49B8DFCDCD.jpeg 35A884E1-261F-4110-8931-7B7733C0B14D.jpeg
    VF-1, Dave Mc, ralphson and 14 others like this.
  8. BILL LUPIANO
    BILL LUPIANO
    from Canada
    Wow that looks good Mr.C.!
  9. twenty8
    twenty8
    How many of you guys have a recessed firewall ???
    It creates legroom issues in the early pickups, and makes it crucial to get the seat/peddle setup right.
    Even then, it helps if you have hobbit genes in your family tree......
  10. Petejoe
    Petejoe
    from Zoar, Ohio
    Here’s some info from a previous thread.
    I’ve added some pictures for clarification.
    Please excuse the rough drawing.
    A lot of the dimensions were taken from the door and floor opening edge.
    Let me know if you need any others.
    I believe the seat is the second or third seat from a 60’s van based on the tubing frame underneath. PJ
    [​IMG][​IMG][​IMG]
  11. And now you see why my 6'4", 300lb *** stopped building model A Ford's :D
    Crazy Steve, nochop, VF-1 and 15 others like this.
  12. Anyone ever looked into leg shortening surgery?
  13. 19Eddy30
    19Eddy30
    from VA
    How many Caught Quick release steering. It makes a lot easier In& Out of my roadster & 32 5w , Im 1/2 fat , 6, 265
    14 feet.
    I even made mistake flat fire wall in 32,
    With out package tray , Will be changing
    bchctybob and Just Gary like this.
  14. rockable
    rockable
    I am 6'2". This is why I don't own an old pickup truck. I like them but I don't fit comfortably and I am into comfort.
  15. Center steering, seating and dropped foot boxes.
  16. My 32 had no chop. I used the mini van seat and removed a lot of the foam from the back. It was against the rear wall of the cab. My memory is fuzzy about this but I don't remember if the bottom was 16 or 14" in the air. I took that measurement from a 2000 dakota that is my daily. The clutch and brake were firewall mounted and were good. The throttle was the one that I had no room for. It was normal for me to 4 hours in one direction to a show. I survived but there was stiffness and some soreness after a real long day. That did have something to do with me selling it after almost 40,000 miles. Getting the pedals and steering wheel location is a big deal in any vehicle. There's a mess of those pickups but few that are driven real long distances and I am a midget. :)
    19Eddy30 likes this.
  17. Jalopy Joker
    Jalopy Joker
    as shown, some have raised the front of seat. Instead of that another option, if you are doing new upholstery, is to the add padding along the front upper edge of seat base. this will help support your legs, since they are bent to operate pedals. also, allows space for padding for rear that you lose by just changing angle of seat. when padding seat back add a little to bottom edge to provide some lower back support.
  18. Flathead Dave
    Flathead Dave
    from So. Cal.
    I'm with the van seat group. They fit nicely.
    ramblin dan likes this.
  19. Born 2 Loose
    Born 2 Loose
    Oh, a wise guy !
  20. Born 2 Loose
    Born 2 Loose
    OK Well youse guys from Virginia are interesting. Thanks for your input (I think).
  21. blue 49
    blue 49
    from Iowa
    My '36 cab is a little bigger than yours but I had the same trouble. I'm using the "way back" buckets from a Chevy FWD minivan. I'm on my 3rd gas pedal placement and my 2nd set of seat risers. The first seat risers had the front of the seat raised slightly but I found that setting them flat moved my hips back a little and helped a lot. I don't think I can get it any better than it is now and it's not bad.
    Gary
  22. gene-koning
    gene-koning
    I sold a just completed 39 Dodge pickup for that very reason a few years ago. The redesigned 48 and newer cabs are a so much better fit.
    Dodge used the same cab 39-47. The 48 cab is 13" wider, and 7 1/2" longer between the firewall and the back of the cab. That extra 7 1/2" is a huge difference.
    squirrel and daylatedollarshort like this.
  23. badshifter
    badshifter
    100 percent. Read and follow. Especially the seat back part.
    You need almost none and it’s still comfortable. 37ACF6F5-97FE-484F-8100-EDF153352C9F.jpeg
    ralphson, Shutter Speed and bchctybob like this.
  24. bchctybob
    bchctybob
    My chopped '29 pickup had a simple custom-made seat, 1/2" plywood with 3' foam on the bottom and 1 1/2" foam on the back, all covered with simple red tuck-n-roll. The seat back was straight up, the bottom had a small riser with about 1 1/2" tilt. It looked like it would be terribly uncomfortable, but it was fine, even on long drives.
    This doesn't bode well for my unfinished '33 pickup, it's chopped 4", channeled 2 1/2", and the firewall is moved back about 1 1/2". Uh oh.....
    High test 63 likes this.
  25. gimpyshotrods
    gimpyshotrods
    Move the engine to the back, so you can move the firewall forward.
  26. alanp561
    alanp561
    o_OAnd, about the time I think you're somewhat normal, you come up with something like this! Good going, you keep my blood pumping. ;)
    Shutter Speed and anthony myrick like this.
  27. A creative bump for the thread.
    Works better than “back to the top”
    alanp561 likes this.
  28. badshifter
    badshifter
    Return it to the web. It’s horrible.
  29. Blues4U
    Blues4U
    from So Cal
    Agreed! I'd rather have less leg room....
  30. Mr48chev
    As several Mentioned, There is a penchant for rodders to want lower the seat cushion in an old truck or car for that matter causing it to actually loose rather than gain leg room. that and the lean back needs to be as straight up and down and as thin as your back will allow and still have reasonable comfort.
    bchctybob, Shutter Speed and X38 like this.
