Projects 'No longer' Pinky the Shoebox rebuild
Discussion in 'The Hokey Ass Message Board' started by Jimbacca, Nov 28, 2012.
  1. Jimbacca
    Jimbacca
    This was brought into the shop earlier this year. It was in for bags and interior updating. The owner bought it online from someone back east never saw it in person until it was delivered. As things were removed the magic started showing up. The car is at paint now so here's the progress so far. It was a 4dr at one point in its life.
    I missed day 1 of tear down.
    Some of the existing supports. Aluminum L Channel
    P***enger side rear bodymount. Yes that is duct tape
    P***enger side over the rear axle bodymount
    Duct tape removed
    Driver side rear mount
    Another driver side rear mount
    The owner wanted to do away with the trim. This was found when sanding began
    Once the console was out we noticed why the owner said it was really hot when he drove it. There was some large segments of the ****** tunnel missing. There was also a slice down the driveshaft tunnel for clearance. Didn't bother welding it together.
    So from interior and bags to a full redo. The owner chose the new color to be white. I'll post up the progress. Enjoy
  2. Jimbacca
    Jimbacca
    Firewall before
    Firewall shaved out.
    New ****** tunnel and driveshaft tunnel undeway
    Interior Floor and fabwork done
  3. Jimbacca
    Jimbacca
    Rear suspension Bodymounts and floor
    Frame notch and plating. The frame is plated from the front subframe all the way back. There was alot of foam and other things holding the rotted mounts and metal together so the flooring and mounts were removed.
    New tube crossmember with rear bodymounts. The existing wasnt attached to anything.
    New rear end. Link bars going in. Crossmembers in. Tank mounts and fuel cell mounts in
    Replacing a bodymount shown earlier.
    Mocking up the watts link
    Rear floor in
  4. Jimbacca
    Jimbacca
    New clip in.
    Shot of the frame
    Frame and suspension painted
    Back on the ground. Core support and front bodymounts still need to be added then on to the bodywork
  5. OldKustoms
    OldKustoms
  6. tomkelly88
    tomkelly88
    Wow, you guys have already done some nice work.
    Almost threw up when I saw this fridge between the front seats! I pleases me to know it WONT be going back in!
  7. Ltorch
    Ltorch
    I think that car was for sale at black tie cl***ics.wow lots of rust but comeing along nice job.
  8. sololobo
    sololobo
    very scary, got it lookin good guys, will be cool when you get done with the revamp. Nice save ~sololobo~
  9. Vonzemo
    Vonzemo
    Hows the old saying go: "Trying to make a silk purse out of a sows ear !!! "
    The car is the right color.
    You definitely got your work cut out for you on this one, but it appears your heading in the right direction. What are the plans for the roof ?
  10. It always amazes me how much money some people have to spend to do something like this to a car. I hope for the new owners sake they got it cheap because to undo all that bad taste and fix all that rust is going to cost a fortune.
    Your shop is doing a great job and look forward to more photo's and the finished car.
    I wish I could afford to have that much work done to my shoebox !
  11. BLUDICE
    BLUDICE
  12. ryno
    ryno
    Looking good. You and brad going to moon eyes?
    I'll be out there. Well have to try and hook up for lunch one day
  13. jerseymike
    jerseymike
    nice work so far, please say the pink paint and rear wheelwell openings are going away!
  14. Jimbacca
    Jimbacca
    Brad owns the shop and does the fab. I take the pics, help sort out any of the wtf's on the projects, and build my studebaker.
    The owner of the car wanted a nice family cruiser. Originally it was redo the interior since it was interesting with alot of marine vinyl and dated. That epic console hid alot of bad things. Once the interior was removed and the ground was visible it turned into what you see.
    Job one was make it safe for his family and have a decent cruiser to take to shows. It will end up with a clean interior, nice looking engine compartment and safe.
    Not sure on the Mooneyes Ryan. Moving shops this weekend for 3x the space and onsite tow gear. Plus gets the studebaker its own area for me to take it down to the frame and go through it all.
    Thanks for the comments. I'll keep the updates coming as moves towards completion.
  15. Jimbacca
    Jimbacca
    Not sure about the roof yet. Once the owner sees it all fixed and back together we will see if his idea changes on leaving it the same.
    The Pink goes away to some form of White. Rear wheelwells will be stock ford.
  16. stanlow69
    stanlow69
    Can you show a pic of what it had for headlights. It`s got me baffeled.
  17. Jimbacca
    Jimbacca
  18. stanlow69
    stanlow69
    37 Ford, I saw the pic`s, nevermind.
  19. Finnrodder
    Finnrodder
    from Finland
    Sounds like your customer has a lot better taste with cars than dude who ever built this.Good luck with the build.
  20. Jimbacca
    Jimbacca
    Brad appreciates the comments. The top is going to be recovered in a tan color with a superior looking product. So we shall see if that helps with the appearance.
    Here's a shot of the custom fuel cell. It will be mounted underneath the new trunk floor.
    One of two airtanks. There is one on each side of the trunk.
  21. Buddy Palumbo
    Buddy Palumbo
    You guys are doing some nice work . It sounds like the car will be a million times better when it leaves your shop .
  22. Stefan T
    Stefan T
    from Sweden
    Nice to do somthing to old custom thars need a restoration
    /Stefan
  23. Jalopy Joker
    Jalopy Joker
    love the ad done by Seller company, especially about winning trophies. it will likely win plenty once you get through with it.
  24. Jimbacca
    Jimbacca
    Some shots with the roof back on before it got shipped to paint. Core support is mounted and all the sheetmetal is gapped.
    Soon to be lowered and properly shaped rear wheelwells.
  25. LeClaire
    LeClaire
    from Minnesota
    UGGH! don't do a tan top, it would look so much better with a black top and interior to contrast the white body. Great job on the repairs though
  26. Jimbacca
    Jimbacca
    Little update
    The paint is done. Just waiting for it to magically reappear for some pictures.
    The windows and top will be modified to have a better look.
    Thanks for viewing.
  27. motoandy
    motoandy
    from MB, SC
    waiting on you!!!!! I like the changes that have been done. Now it seems to be on the right track. Is the interior going to have a bench seat, or keeping the buckets???
  28. Jimbacca
    Jimbacca
    The shoebox has returned. It's back from paint and re***embly is underway. Heres some shots of it. I'll get more when I get over there tomorrow.
    The new factory type wheel opens came out nice. The door is open so that is why the colors look off.
    Here's a shot of the p***enger side cowl area.
    Front shot.
    Thanks for viewing the progress
  29. Jimbacca
    Jimbacca
    Attempt #3
    The trunk and floors are getting ac***at to keep the sound down since it will be a family cruiser.
    Shot of the new factory height wheel openings
    Composite shot of the car
    Wiring harness installation started. We will be cleaning up the frame and engine compartment.
    Thanks again for viewing the build and the messages.
  30. daddio211
    daddio211
