No oil filter!
Discussion in 'The Hokey Ass Message Board' started by 53baldmohawk, Dec 16, 2006.
  1. 53baldmohawk
    53baldmohawk
    from Valencia
    My 53 chevy 235 has no oil filter, whats the deal?:confused:
  2. 54BOMB
    54BOMB
    It wasnt standard back then, some had an add on filter attached to the manifold.
  3. 53baldmohawk
    53baldmohawk
    from Valencia
    Do you know were i can get one and or pics of one. THANKS ANDY
  4. 54BOMB
    54BOMB
  5. Big Tony
    Big Tony
  6. 49ratfink
    49ratfink
    everything you could ever want will be for sale on ebay sooner or later. or you could post a "wanted" ad here on the HAMB. this place is crawling with people who have chevy sixes. I've had a few myself.
  7. 53baldmohawk
    53baldmohawk
    from Valencia
    Thanks all just got my car today and i was poking around and noticed no filter. Andy
  8. zman
    zman
    from Garner, NC
    Even the canister filter wasn't full flow, so really it doesn't do much. Just change the oil every 3k and roll.....
    Or do the full flow conversion...http://www.inliners.org/ go to tech tips and check the full flow conversion...
  9. 53baldmohawk
    53baldmohawk
    from Valencia
    Thanks ZMAN in the future i'm going to change the power trane, so i'll stay on top of the oil change. ANDY
  10. squirrel
    chevy recommended changing the oil every 1000 miles back then. You know, the really wierd thing is that these old engines lasted a long time without a filter! makes you wonder, eh? maybe you don't need one so bad after all
  11. hvychvy
    hvychvy
    I got one from FLAT-TOP BOB here on the hamb,try sending him a PM maybe he's got some more,then you can have some lines made at your parts store.One line goes in where your sending unit goes,and the other on the p***. side of the block,about in the middle,below the valve cover.It should have a small square headed plug,I'm guessing about 1/4 inch.
  12. The byp*** oil filter was about as effective as having no filter. Change the oil every 1K and you'll be sweet.
  13. 55 dude
    55 dude
    go to inliners.org or stovebolt.com looked at article on remote oil filter for 235 yesterday, ton of great pic's!
  14. Bugman
    Bugman
    Filters are over rated :D I've got a pair of magents stuck to the oil pan right next to the drain plug. I pull the plug, then pull the magnets, anything stuck there gets drained out.
    (As a side note, air cooled VWs didn't have factory oil filters up until the early 90s.)
  15. I put an aftermarket spin-on filter on my old 216. No big deal.
  16. Squablow
    Squablow
    My 216 has an aftermarket filter that takes a roll of toilet paper as the element.
  17. limited oil pressure to get the oil around
    kinda depends on gravity to circulate
    just look at the stick and change often
    remember you have babbit bearings ....
    synthetic anyone ?
    i did amzoil and consumption is down
    just costs more now to change/add in my 50 chev sd
    newer filterkits are availible from fram /napa used on tractors and the like ....smaller ez mount cannister than old stockers use flex hose from grease guns
    paperdog
  18. Brandy
    Brandy
    from Texas
    What a nasty mess. I'd just change my oil every 1000 miles, if I was that worried I do the magnet trick, but I can't be bothered to get past that filter element.
    I'm getting crabby in my old age.:D
