Hot Rods No pcv on 409
Discussion in 'The Hokey Ass Message Board' started by Gus68, Jul 4, 2023.
  1. Gus68
    Gus68
    from Minnesota
    So. Almost 2 years ago i rebuilt a 409 to put in my 62 Bel Air. 10 to 1 comp. A good blumpty blump Bullet cam and the new edelbrock single 4 barrel intake. When i put the intake on it said not to put a pcv in the hole in the rear of the intake. But made, what i THOUGHT, was a good baffle on the under side, and put a pcv valve in therr anyway. Well, i seem to slowly burning oil, and im thinking thats it. So my question is, do you guys think that just a breather on the fill tube in the front of the intake would be enough ventilation? I REALY dont want to drill holes in my valve covers!
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    the hole on the back of the intake is supposed to go to the road draft tube originally, the road draft tube and the front breather was enough from the factory. It is probably a bad idea to plug that rear opening if that is what you are thinking
    Bob Lowry and 427 sleeper like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    I suppose you could set up a pcv system like the L79 327's had. where there is a non breather cap on the fill tube, a fitting on the side of the oil fill tube with a pcv valve in it and then a tube running from the hole in the rear of the intake to the bottom of the air cleaner for fresh air in. @DDDenny has good pics of the L79 system
    '40 Coupe Fan likes this.
  4. Taboo56Chevy
    Taboo56Chevy
    if you do the L79 style PCV setup, you need a oil separator that is mounted in the valley as well.
    that goes to the same hole as the draft/pcv tube to the base of the air cleaner
  5. Gus68
    Gus68
    from Minnesota
    I do have a filler tube with a cap and a ****** for a hose that i could use. Couldi just run some type of breather on the rear intake hole and not make an oily mess
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    Just run a tube from there to a fitting on the bottom of the air cleaner @DDDenny has good pics of the L79 setup
  7. DDDenny
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. saltflats
    saltflats
    from Missouri
    Run the PCV to your oil fill tube with a sealed cap then run a hose from the rear of the intake to the inside of your air breather. That is how it was done in 64 on the 409.
    427 sleeper and Johnny Gee like this.
  10. DDDenny
    I actually forgot the W engines down draft tube mounted horizontally, but here's a little creativity that @dana barlow used on his Y-block for inspiration.
    dana barlow likes this.
  11. DDDenny
  12. saltflats
    saltflats
    from Missouri
    That's it.
    427 sleeper likes this.
  13. Gus68
    Gus68
    from Minnesota
    I might come up with some sort of breather for the rear. Maybe even a remote breather. I am also running a "fly eye" air filter and would rather not tie into that. But i like the idea!
  14. Gus68
    Gus68
    from Minnesota
  15. Gus68
    Gus68
    from Minnesota
    Yes. My NEW edelbrock intake doesn't have the hole for the old road draft tube. It has a hole infront of the distributor. Edelbrock said to run a hose to the air cleaner. But being i didn't want to poke a hole in my air cleaner, and ive always ran a pcv in my cars. I thought i was smarter! Ha!
  16. Starlinerdude
    Starlinerdude
    from Washington
    Sounds like your edelbrock intake doesn't have the stamped steel heat shield/labyrinth oil separator riveted or bolted to the bottom like the factory intakes do so as was suggested earlier find the L79 type oil fill tube with the PCV fitting and reverse the PCV flow direction make sure to get a correct oil fill tube though and don't fabricate one the correct oil fill tube has tongue shaped baffles angled downward in it so that it doesn't impede oil draining down it but stops oil drops from being flung up. Then fresh air supply goes into the hole in front of the distributor and crankcase vapors get pulled up the oil filler tube into the PCV fitting out the hose to the carb base.Guys have tried the L79 type system without the baffled oil fill tube and got the same results you did.
  17. saltflats
    saltflats
    from Missouri
    If you run the rear breather to a remote filter, it will need to be serviced to keep it clean.
  18. 427 sleeper
    427 sleeper
    If you have room between the hood and air cleaner, you could use a 1" spacer between the carb and air cleaner, drill and tap a hole in the spacer, install a ****** for a fresh air source, and run a hose from the intake to the spacer, and still run a PCV valve in the fill tube.
    Moriarity likes this.
