no power to hei when cranking engine
Discussion in 'The Hokey Ass Message Board' started by fordal, Feb 9, 2017.
  1. fordal
    fordal
    Help. I have a 302 sbf in a 1960 ford panel truck with a hei distributor. Worked great when first installed. Now this is what is going on. Turn key on and i have power to hei turn key to start engine turns over but lose power to hei let go of key engine fires up. Engine runs and gets up to temp. Turn to off motor stops try to restart and won't. Turn key on and jump solenid and it fires right up. What could cause to happen.
  2. Try posting this on the general discussion board for all to see.
  3. jimcolwell
    jimcolwell
    from Amarillo
    What kind of wiring harness? I bet it had a reostat that you burned off. Wire around it.
  4. I had much the same problem,but with a GM HEI. I ran a new #10 wire from a switch controlled circuit the Distributor. Problem solved. I never did sort out the original problem.
  5. brokenspoke
    brokenspoke
    HEI needs a full switched 12 volts
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    In both the start & run position...
    belair likes this.
  7. Montana1
    Montana1
    I had an OT Chevy Monza do that with HEI on a 262 V-8. It would crank over and when I'd let off the key switch it would fire. Sometimes it would start. I found it was the remote ignition switch on the base of the column went bad. Changed it out and it ran fine.
    You might also look at the remote solenoid as a culprit. ;)
  8. GMBOWTYE
    GMBOWTYE
    from Ames IA
    Fords used a 4 post starter relay 1batt 1 starter 1 ign feed 1 crankfeed. when you crank
    it it energizes the ign feed which is your 12 volt feed to dist I think the relay has 2 batt terminal
    size posts & 2 slide on connectors
    Mr48chev likes this.
  9. Ignition switch?
    sunbeam and Montana1 like this.
  10. d2_willys
    d2_willys
    from Kansas
    Put a diode from the start terminal to run terminal on the ignition switch. Cathode (banded end) goes to the run terminal. You might lose a volt or so from diode drop, but should work if HEI is within specs.
  11. FrozenMerc
    FrozenMerc
    GMBOWTYE is on the right track, if you are using the Ford Solenoid. Either it is the wrong Solenoid, a bad solenoid (the internal contacts do burn out), or it is wired incorrectly.
    If it was mine, I would throw that the HEI in the garbage, that is for Chebbie's, and get a DuraSpark II setup. Much easier to deal with in the long run.
  12. Ignition switch is shot.
  13. porkshop
    porkshop
    from Clovis Ca
    Needs the wire from the starter solinoid inner small post joined into the circuit to supply 12 volts in crank. Will see if I can find a picture....
  14. porkshop
    porkshop
    from Clovis Ca
  15. Bad switch
    Montana1 likes this.
  16. porkshop
    porkshop
    from Clovis Ca
    Just pretend the picture of the coil is the square Hei type.....John
  17. Montana1
    Montana1
  18. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I've found 2 different types of ignition switches..... power on the ign post when cranking, and the Ford style with no power on crank. The Ford style requires you wire in a starter solenoid and connect HEI power to the "I" terminal on the relay (as well as 12v on run). Take a meter to the switch and check continuity from the power post to ign post when in the crank position.
  19. I really doubt it's the switch, if it's the original style Ford wiring. It is either a bad Solenoid or the wire from the start position on the solenoid to the dist has failed.
  20. Mr48chev
    Yep and not the only one that does that. Some GM rigs work the same way and have no power to the coil when the key is turned to Start as the resistor bypass wire supplies the power to the coil while the engine is cranking.
    Simple solution is to run a wire from the ign post on the solenoid to the wire feeding the distributor and you are done.
  21. southcross2631
    southcross2631
    Put a hidden push button in it . Turn the key push the button. Good anti theft device.
  22. porkshop
    porkshop
    from Clovis Ca
    still the same the Ford solenoid has two small posts one ignition one for start. They are even labeled S and I ..,.
  23. RmK57
    RmK57
    x 1000
