Projects No power to ignition switch
Discussion in 'Traditional Hot Rods' started by 1124jhh, May 2, 2023.
  1. 1124jhh
    1124jhh
    from Auburn,CA
    40 ford coupe with 8BA traditional hot rod. All was well until no start, found no power to ignition switch from fuse block. Hot wired from solenoid to switch and it started. All fuses in block are good. Do I have a bad fuse block ?
  2. jaracer
    jaracer
    You need to trace the hot wire from the ignition switch to the fuse block. You also need a voltmeter or at least a test light so you can pin down where the circuit is open.
    1oldtimer and TagMan like this.
  3. GregCT.
    GregCT.
    from CT.
    if you have the original on off switch and starter ****on- check to see if the wire nuts are tight behind the column drop.
